Test Pipes staining my IP coupe
Old Sep 16, 2007 | 05:26 AM
G35JCC's Avatar
G35JCC
Angry Test Pipes staining my IP coupe
The carbon sh*t that pukes from my exhaust is staining my rear bumper. I'm assuming it's from the TP's. It is very noticeable with white. Has anybody had this same issue and is it permanent?
Thanks
Old Sep 16, 2007 | 06:00 AM
Z04's Avatar
Z04
all exhausts have some degree of black that comes out the rear. if it is staining your rear bumper you do not have your exhaust positioned correctly.
Old Sep 16, 2007 | 06:04 AM
HondaKiller's Avatar
HondaKiller
+1
that was the hardest part about hanging the exhaust correctly on my set up. Adjusting the tips to be far enough way from the bumper and somewhat level to one another using the stock mounts was a *****. Time to make some adjustments if your bumper is covered in soot.
Old Sep 16, 2007 | 06:13 AM
G35JCC's Avatar
G35JCC
I'm assuming you think they are pointing slightly upwards. I'll get them bent a little toward the ground and see if that helps. Thanks for the help.
Old Sep 17, 2007 | 06:27 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Welcome to test pipes....
HFC's don't have the issue...
Rick
Old Sep 21, 2007 | 10:12 AM
jdepe's Avatar
jdepe
i have this very problem also. on my ip coupe. my bumper and carbon diffuser have yellow junk all along the bottom near the exhaust tips. looks like oil but idk.
Old Sep 21, 2007 | 11:32 PM
Yes I have test pipes.
Yes the rear bumper gets dirty.
A little wax takes care of it.
Old Sep 22, 2007 | 09:35 AM
doskiez's Avatar
doskiez
My car does the same thing....wash often and use a clay bar if the staining gets to be too bad or where you cant get it off with normal washing
Old Sep 22, 2007 | 11:40 AM
TreeZ's Avatar
TreeZ
i use meguiars scratch-x. it takes it off with no effort. wax takes some elbow grease but works too.
Old Sep 22, 2007 | 11:45 AM
ISMSOLUTIONS
The staining is mostly due to the blow by through the system. These cars burn oil...and a decent amount of it. Like others have posted already, a little wax goes a long way, maybe a clay bar every few weeks.
Rick
Old Sep 22, 2007 | 12:55 PM
moog's Avatar
moog
Yeah i collect a lot of stains on my Ings rear skirt. It comes off w/ some elbow grease.
Old Sep 22, 2007 | 01:14 PM
SuperBlack350z's Avatar
SuperBlack350z
wax would seal that black stuff in so you dont' want to do that. Scratch x would work though.
Old Sep 22, 2007 | 02:00 PM
wayneside's Avatar
wayneside
like the others said...wax will do the trick! i use some Meguiars cleaner wax and then follow it up with a few coats of Meguiars NXT wax...then its easier to wipe off for a little while.
don't let it cake on though!!!
Old Sep 22, 2007 | 02:04 PM
G35JCC's Avatar
G35JCC
Thanks for the replies guys. I definately don't like this sh8t on my back side. Washed it the other day and the stains seemed to be gone, but after I drove about 5 miles to Wal-Mart I noticed the back looked like it had never been washed! If those 300 cell cats that Fast Intentions sells don't kill my power and removes the carbon i'm going that route. How much power will I lose with HFC's? I've got the JWT TT's and Greddy evoTT exhaust BTW.
Old Sep 22, 2007 | 03:12 PM
supra crazy's Avatar
supra crazy
A easy way to remove the "stain" is with some bug/tar remover I have the same problem with my car it comes right off with the bug and tar remover.
Old Sep 25, 2007 | 12:02 PM
gothchick's Avatar
gothchick
Sounds like your afr's are way too rich - or you've got major blowby. A tune & catch can might help. Might also want to get a compression check to see what's going on.
Old Nov 1, 2007 | 05:59 AM
jdepe's Avatar
jdepe
mines stilll bad. it wont come off at all =(
Old Nov 1, 2007 | 08:32 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The gains from cats are roughly 1/2 that of test pipes.
Old Nov 3, 2007 | 01:44 AM
Chineseguy's Avatar
Chineseguy
Welcome to my world.
The way I clean it off completly is by using K&N filter cleaner. might sound weird but it works. comes right off once you spary it on the bumper.
Old Nov 3, 2007 | 08:40 AM
moog's Avatar
moog
Simple green works just fine too
