ITB's available soon
Old Oct 12, 2007 | 11:46 AM
  #41
03BrickyardZ's Avatar
03BrickyardZ
Originally Posted by Motormouth
why do people keep saying stock ECU? jeez...
More importantly, why would anyone spend 3500 on ITBs without spending the money on a decent ECU?
Old Oct 12, 2007 | 07:02 PM
  #42
XIceDragonX's Avatar
XIceDragonX
Why wouldn't you just make it so that one side of the throttle bodies be controlled like the normal drive by wire, and than do a connecting rod from the bottom of that one to the top of the other banks bodies to eliminate the need for two throttle cables and simplify the kit? Why adapt what can be salvaged? Just my 2 cents on that theory... although a direct cable to the pedal would be nice in that you would have complete control...
Old Oct 12, 2007 | 07:52 PM
  #43
jonnylaw's Avatar
jonnylaw
Please make me this for $3.5k:
"Individial Throttle Body (ITB) Setup
Includes gold funnels, fuel rail, etc.
(requires ECU tuning)"
Top Secret makes a proper ITB setup. The air box is carbon fiber. $6k for the TS ITB's, I dunno how much the carbon airbox is.
Old Oct 12, 2007 | 08:07 PM
  #44
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Ya, I began thinking about the Top Secret ITB setup too when this thread got started. I wonder what the difference(s) are between the Jenvey system and the Top Secret version (other than price of course).
Old Oct 13, 2007 | 02:49 AM
  #45
Devil Z's Avatar
Devil Z
What kind of advantages does ITB's give to a FI car?
Old Oct 13, 2007 | 04:52 AM
  #46
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yeah, that would really simplify the kit
simple is a throttle cable operated setup....complex is a drive by wire one
let's just not mix words though...this is not a setup for a stock car, or a car with even bolt ons
Old Oct 13, 2007 | 04:54 AM
  #47
Z1 Performance
Former Sponsor
johnnylaw - that's essentially what this is. There are only a few ways to skin a cat
devilz - a long conversation to do here, but do some googling, etc on ITB+ turbo. It can be very rewarding, but requires the use of a standalone (need lots of resolution to do this properly on an FI car), and alot of patience with the tuning and setup of the ITB.
Old Oct 13, 2007 | 01:37 PM
  #48
xlr8r's Avatar
xlr8r
It seems like the Top Secret ITb's are geared more towards Boost, while the Jenvey's are more for NA, but could be used for turbo with custom manifolds.
Old Oct 13, 2007 | 09:24 PM
  #49
jonnylaw's Avatar
jonnylaw
those ts anodized trumpets are soooo hawt!
Old Oct 14, 2007 | 08:33 AM
  #50
LHP's Avatar
LHP
Lets put this to rest,
Using the stock ECU with this ITB system will never get the results you want.
As for running an airbox with a MAF sensor, not the hot setup,
they will not keep up with the gulp factor of the ITB's,
let alone work with the harmonics in the airbox, unless the airbox is huge.
(Meaning it won't fit under a 350Z hood).
Maf sensors want true one way airflow, you put any back flow or weird harmonics into the flow and you're hurtin, and hard to tune.
Will not work with Fly by wire,
too many throttle return springs for the e motor to work with,
and liability out the yingyang.
Would have to make up a vacuum tree of sorts for power brakes,
and or Map sensor.
$3500.oo for the ITB system and the airbox,
I will believe that when I see it,
and I'm the first of the Jenvey dealers in North America.
My pricing with the U.S. dollar right now puts the throttle system without any airbox or TPS at $3800.oo usd (retail pricing).
the U.S. dollar is dropping like a fly right now on world markets.
This system was supposedly designed for Nismo,
for Paris/Dakar and rally style racing.
LHP
www.haywardperformance.com
Old Oct 14, 2007 | 09:47 AM
  #51
Quamen's Avatar
Quamen
Personally I like the Jenvey design better than the Top secret. It just seems more functional. While Top Secret makes some dope **** I think that their design is not as straight forward and simple as the Jenvey. My main draw back with the Top Secret is that no one can really tell what the transition plate from the throttle bodies to the heads looks like air flow wise. It could be just an oversized hole that creates turbulance at the ports on the head for all we know. You can see that the Jenvey unit, having completely cast runners, looks to have a straighter and more laminar flow through the runners and since it is a casting I would bet that the part that meets the heads is just slightly oversized to allow for ported and polished heads but is fairly symetrical to the design of the OEM ports.
Just my
Old Oct 14, 2007 | 09:53 AM
  #52
Quamen's Avatar
Quamen
Another thing that I just noticed is that if you look closely at the runners on the Jenvey unit right before they meet the heads they are slighlty bend downward right there. From just looking at the pictures this is a great design because it allows the injectors to still spray the back of the valves while being further up stream. The good thing about being upstream further is that at higher RPM's and air velocities the more time you have to atomize the fuel the better. There are a number of college Formula teams that have played around with staged injectors (one set close to the heads for low rpms and one set further from the head at high rpm for better atomization) and have had good resaults. Since this will most likely be used on a high revving motor I think that this is the better thought out design and they put more into it then just "making an ITB setup".
Looking at the Top Secret ITB's the main reason I think they went the route they did was to avoid making a casting or 5th axis machine something that they might sell two of considering their prices.
Old Oct 16, 2007 | 05:17 AM
  #53
xlr8r's Avatar
xlr8r
When is Zxman going to post in this thread again & update us on when he will actually sell these & the throttle plate size? This thread is going to die if he doesn't join it again soon.
Old Oct 16, 2007 | 06:02 AM
  #54
ct350z's Avatar
ct350z
subscribing
Old Oct 16, 2007 | 06:05 AM
  #55
ACEMAN's Avatar
ACEMAN
Master
Originally Posted by ct350z
subscribing
Thread Tools Work aswell.. YOU NOOOOOB!!!
Old Oct 16, 2007 | 06:31 AM
  #56
ct350z's Avatar
ct350z
dam your like a fly over shat...lol
Old Oct 16, 2007 | 08:45 AM
  #57
NA&CH's Avatar
NA&CH
He said he should have them this week. I will meeting up with him when he does To take some pics caress and hold them
Chris
Old Oct 16, 2007 | 09:00 AM
  #58
buzzardmountain's Avatar
buzzardmountain
Chris
Take lots of pics......
Old Oct 16, 2007 | 03:16 PM
  #59
bimmertech's Avatar
bimmertech
and or Map sensor.
i do agree that a stock program will never gain intended results.
you can run a maf/airbox and it does work--see any BMW M car since 1988(cept the usdm E36)
you can run a throttle by wire and it does work--again bmw been doin it for a while.
as for the vacuum tree, think of another fuel rail lookin thing right after the throttle blade with vacuum ports--you guessed it.
the only real downside to itb's imo is the fact that your cam timing will no longer be tuned for the decrease in wave pulses. this can seriously hurt low speed torque. i for one will not be buying itb's, but they are cool.
Old Oct 16, 2007 | 05:33 PM
  #60
LHP's Avatar
LHP
The throttle systems on BMW's are designed by the engineering might of BMW and with a special Bosch management system to work with the MAF that is special to BMW.
We are talking about a throttle system that would be at best,
tuned by a shop, local to the person buying it, not a major auto maker.
I have a customer that has broken in to the Bosch computers and has tried to do the MAF thing and said it was all compromises to make it work,
not the best of situations.
Not the dedicated BMW computer.
As for cams/timing,
you can now go more radical with cams and still have reasonable drivability with an ITB intake system.
LHP
