I've decided on a set of Berk HFC. Do I get metallic or ceramic?
Old Oct 9, 2007 | 09:56 PM
Beeker's Avatar
Beeker
Default I've decided on a set of Berk HFC. Do I get metallic or ceramic?
I've been putting off getting a set of high flow cats for a long time. I've finally decided to give Berk a shot. High flow cats are the last bolt on I can add before I go internal.
Should I go with the standard ceramic cats for $299.00 or the metallic substrate for $399.00? I don't want my exhaust note to be too much louder so I am leaning towards ceramic. Plus I am almost broke so saving a hundred on ceramic sounds good to me. If metallic is worth the extra $100.00 then I will pay it but if it only makes a 1-2 hp difference with NA then I would rather save the extra noise and the $100.00.
Keep in mind that I plan on staying NA and this is my last mod. I already have Osiris and once I add the high flows I will be getting dynoed so Uprev can give me a custom tune.
Old Oct 10, 2007 | 05:41 AM
ZLadie2000's Avatar
ZLadie2000
Hopefully Berk can answer this question...
Old Oct 10, 2007 | 06:31 AM
rcdash's Avatar
rcdash
Based on your requirements, ceramic.
Old Oct 10, 2007 | 07:00 AM
stylett9's Avatar
stylett9
https://my350z.com/forum/vq35hr/305963-berk-technology-2007-hfc-s-are-finally-finished-pictures-inside.html
see post 11
Old Oct 10, 2007 | 10:01 AM
Beeker's Avatar
Beeker
That is what I was thinking. Ceramic should be fine for NA. If I was going to add a turbo kit then metallic would make a lot more sense.
Old Oct 14, 2007 | 03:39 PM
black06z's Avatar
black06z
Get the ceramic Berk HFC's.
Old Oct 14, 2007 | 05:13 PM
chriskabobbers's Avatar
chriskabobbers
berk tp's =D
Old Nov 12, 2007 | 11:33 AM
Beeker's Avatar
Beeker
I just ordered a set of Berk ceramic cats.
It is almost time to put my car away for the winter. I am going to try to get them installed before that. I will post again once I get them installed.
3vilbunny
Jul 18, 2017 05:10 PM
