Resonated test pipes rubbing...
Old Oct 29, 2007 | 03:24 PM
PearlZzZ's Avatar
PearlZzZ
Default Resonated test pipes rubbing...
I recently had a pair of resonated test pipes installed at a local shop. Paid stupid money to have them put in when i could have done it myself. And now i discover that the resonater is rubbing against the frame of the car right above the heat sheilds.. Its causing extreme vibrations through my car on decell because of the exhaust movement.. I called kinetix and they said to take them off and "Bash" the area that its hitting in with a mallet. Before I go "bashing" my car in with a mallet I have a question. How much do I have to indent the frame to allow enough room for the resonator to have clearence? Is this safe to do?? Also when they were installed the bar that holds the stock cats in place was removed.. The res test pipes dont have a flange or mount to uttilize it.
Old Oct 29, 2007 | 03:46 PM
gsazabi's Avatar
gsazabi
It all depends on how much of aclearance you have. Just bash in the heatshield as far in as you can for extra added safety.
It's completely safe to do so. Some people even gut it out and have no problems.
Old Oct 29, 2007 | 03:52 PM
PearlZzZ's Avatar
PearlZzZ
I dont even think its the heat sheild though.. It would be making a different sound. Its actually the Frame of the car itself. Its about 1/4 of an inch away from the frame about 5 inches up from the sheilds and it vibrates like crazy when u let off the gas. Do you have test pipes in your car? Do you have the mount the holds both cats together? Im gonna snap some pics of exactly where its hitting tomorrow when i jack it up , but untill then i need to be sure this is an ok thing to do
Old Oct 29, 2007 | 04:06 PM
gsazabi's Avatar
gsazabi
What kind of crappy designed TP will actually make contact against the frame?
I've never heard/seen this unless it's making contact against the heatshield.
Is it the resonator section that's being rubbed against the top???
Yea I used to run two different kinds of TP(now HFC) and never had this problem.
Old Oct 29, 2007 | 04:19 PM
Alvinpv's Avatar
Alvinpv
if you still have the stock y pipe on your car it makes noise with tps....the flex joints i think make it....mine make a rattle noices when i let off the gas but they are not hitting anything
Old Oct 29, 2007 | 04:23 PM
gsazabi's Avatar
gsazabi
Yea high possibility that it's the infamous TP noise rattle/hissing.
Old Oct 29, 2007 | 05:04 PM
06MagneticZ's Avatar
06MagneticZ
nope. ALL of the tp's Ive ever owned rattle or make contact with something. The hissing rattle sound is also present. From the stock y pipe to the Nismo. Hisses/rattles whatever. It comes from the flex joints. Dont know why.
Old Oct 29, 2007 | 05:15 PM
PearlZzZ's Avatar
PearlZzZ
Yes , its the resonator thats hitting against something. My brother has a G35 and he never had this issue with them , they were taken off his... I think I know which rattle your talking about because my brothers does it. He has Kinetix non resonated test pipes. Trust me this feels like someone is taking a spackle mixing gun and running it under console.
Old Oct 30, 2007 | 05:26 AM
HKS-Z's Avatar
HKS-Z
Backroad Pro
Get used to the rattle,your not going to fix it...trust me,just turn the radio up.
Old Oct 30, 2007 | 05:40 AM
Mike Wazowski's Avatar
Mike Wazowski
Kinetix of course. The worst of the worst.
OP: cut your losses and get a set of high quality test pipes and learn the lesson "stay away from Kinetix"
did I mention that I HATE kinetix.
Old Oct 30, 2007 | 06:26 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
+1000000
Get FI testpipes...
Old Oct 30, 2007 | 07:13 AM
Snow-G's Avatar
Snow-G
Ive got AAM's test pipes and the drivers side will rub on the frame as well. There is like a 1/4 gap from the frame to the flange. I also have the stock Y pipe but dont know if this would help to change out. It sounds horrible!
Old Oct 30, 2007 | 02:02 PM
Alvinpv's Avatar
Alvinpv
yes fast intentions ftw....i have not had a problem with them yet and they look so well made
Old Oct 30, 2007 | 02:53 PM
It either fits or it doesnt.
Loosen all the bolts.
Put a 1/2-inch piece of wood between the test pipe and frame.
Lighten the bolts.
Remove the wood.
Old Oct 31, 2007 | 07:56 AM
gothchick's Avatar
gothchick
Lighten the bolts.
Remove the wood.
+ 1. Some advice that is actually helpful~
BTW; there is nothing wrong with Kinetix RTPs or Non Res TPs... I wouldn't get any of their plenums though.
Old Oct 31, 2007 | 08:44 AM
CC Z33's Avatar
CC Z33
Does FI make test pipes for the 07 HR?
Old Oct 31, 2007 | 08:58 AM
gothchick's Avatar
gothchick
Yes...
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
