1/2 inch MD spacer question?
Old Nov 11, 2007 | 01:09 PM
JasonZ-YA's Avatar
JasonZ-YA
Default 1/2 inch MD spacer question?
can u give me a clear answer?
with the 1/2 inch spacer can u use the stock strut bar? I dont mind using spacers/washers to make it fit?
I just dont want to "have to" purchase an aftermarket strut brace bar.
I have also heard of the hood hitting the strut bar due to the 1/2in spacer? I don't mind the hood hitting, I just want to know if it works?
-jason
YES IVE SEARCHED...
also, anyone have pics with washers to make it fit?
Old Nov 11, 2007 | 03:06 PM
JasonZ-YA's Avatar
JasonZ-YA
nothing yet?
Old Nov 11, 2007 | 03:07 PM
ssgohan434's Avatar
ssgohan434
No, the 1/2" spacer will NOT allow you to keep your stock strut bar.
p.s. this is the "for sale" section btw
Old Nov 11, 2007 | 05:50 PM
Old Nov 11, 2007 | 05:53 PM
Motormouth's Avatar
Motormouth
I have my strut bar on with my 1/2 inch spacer, NO strut bar spacers
I simply cranked the adjustment on the bar until there was clearance. I do not have any rubbing that I can feel and there is no noticeable wear on the plenum now (before I adjusted it again, yes there was some rubbing but not now)
no washers, no nothing.
Old Nov 12, 2007 | 05:23 AM
gothchick's Avatar
gothchick
Not sure if cranking up the preload that high on the strut bar is good for suspension, alignment, etc.... I just used the spacers that came from Motordyne.
Old Nov 12, 2007 | 05:32 AM
JasonZ-YA's Avatar
JasonZ-YA
okay, so then it will work?? Gothchick, with the spacers you used does the stock strut bar now hit the hood? also do you have pics?
-j
JasonZ-YA's Avatar
JasonZ-YA
davidv,
thanks for your post, ive seen that, but i know ive heard of people saying you could still do it?
Old Nov 12, 2007 | 06:29 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
There are people who can do it due to car to car tolerance variations, but its not 100%. ...Probably less than 50%.
It took a lot of time and lots of test cars to find 5/16" as the optimum for the Nissan fleet.
Motormouth's Z is a good example of an extreme of tolerance variation. A 1/2" spacer and no strut bar spacers at all?
...I would have never guessed it was possible.
Old Nov 12, 2007 | 07:37 AM
JasonZ-YA's Avatar
JasonZ-YA
okay, 5/16 it is........might as well not bother with it.
Old Nov 12, 2007 | 07:40 AM
Good choice.
Old Nov 12, 2007 | 07:43 AM
Motormouth's Avatar
Motormouth
and I have lots of room. I was surprised as well, it hardly (it being the strut bar) rubs on the hood if at all.
I'll take a pic when I have a chance, and thanks for the spacer offer Tony You are always helping us owners out!!
Old Nov 12, 2007 | 09:00 AM
gothchick's Avatar
gothchick
-j
Sorry, I should have been more clear... I have the 5/16" spacer.
Old Nov 12, 2007 | 01:01 PM
TheJerk's Avatar
TheJerk
Originally Posted by davidv
Good choice.
Bad Choice. He will be making more Upperend power with the 1/2. And that is a good thing. The Z has more than enough low end power, the crap *** top end is what hurts.
Old Nov 12, 2007 | 01:02 PM
Motormouth's Avatar
Motormouth
dyno tests showed a 1-2hp difference between the 5/16 and 1/2 inch.
do you have proof of more topend power?
Old Nov 12, 2007 | 01:06 PM
TheJerk's Avatar
TheJerk
Why yes, I do.
Your making peak power closer to redline for longer powerband. Notice how the 5/16's spacer starts falling off.
Old Nov 12, 2007 | 01:07 PM
TheJerk's Avatar
TheJerk
Who actually pays money to turn a Rev-up to a Pre Rev?
Old Nov 12, 2007 | 01:10 PM
Motormouth's Avatar
Motormouth
look at the scaling of the graph... you notice that it is within 1-2hp at the point you are talking about right?
which is exactly as I stated it was... so, I don't get your 'proof' of a significant (my word, not yours) top end advantage.
most builders on this site seem to attribute a flow bottleneck to the lower plenum runners into the heads. just a thought.
Old Nov 12, 2007 | 01:11 PM
Motormouth's Avatar
Motormouth
alot of people actually.
and that isn't a accurate statement either... which you have to stop with that...
Old Nov 12, 2007 | 01:13 PM
TheJerk's Avatar
TheJerk
*laughs* I love how they cut off the Graph right were the 5/16's Makes peak power, while we all can see the 1/2 inch/Crawford Gaining. At redline, I'd imagine there would be a greater difference.
And I didn't use the word "significant" until now.
