header install problem
Old Dec 2, 2007 | 06:35 PM
track04's Avatar
track04
Default header install problem
does anybody have a suggestion on removing the u-joint from the steering shaft?
i loosened both bolts, but nothing seems to budge.
any ideas?
Old Dec 2, 2007 | 06:37 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Mark it so it goes back in the same exact place or it will cause you problems. Remove both 12mm bolts. Pry up with screw driver or pry bar then pull off shaft that goes to steering wheel.
Old Dec 3, 2007 | 06:56 AM
gothchick's Avatar
gothchick
That's one way to do it... Another option is to slip the header in from the top/front. Although with mine, we did have to loosen the motor mount & rock the engine slightly to get the driver's side header to go in. Passenger side was a snap.
Old Dec 3, 2007 | 06:58 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Yeah ive see that work i just found it eaiser if i removed the steering knuckle
Old Dec 3, 2007 | 07:00 AM
gothchick's Avatar
gothchick
Yeah, it probably couldn't hurt to get all the room you can in there. It's pretty d@mn tight.
Old Dec 3, 2007 | 07:14 AM
App6MT's Avatar
App6MT
Loosen the bolts and push the shaft back into the steering column, should come loose no problem.
Old Dec 3, 2007 | 07:37 AM
track04's Avatar
track04
what did you push with?
i tried by hand and mine wont budge.
i drive the car in the winter, so some of the bolts down there are a little rusted.
Old Dec 3, 2007 | 07:55 AM
gothchick's Avatar
gothchick
The shaft itself doesn't move. It's the coupling that moves. The coupling should just slip off the spline (going in an upward motion). But mark it first with whiteout or something, so you can align it when you put the u-joint back in.
Undo these two bolts (I think they're 12mm), then slip the entire coupling up and off the steering column.
Old Dec 3, 2007 | 10:18 AM
track04's Avatar
track04
thanks for the info
ill try that tonight
Old Dec 3, 2007 | 03:11 PM
Is this the knuckle you are talking about? Spray with some penetrating fluid. Remove the bolts completely.
Old Dec 3, 2007 | 04:08 PM
App6MT's Avatar
App6MT
Sorry I couldn't respond sooner but it looks like everyone has given you the answer.
I honestly don't know why you need to loosen the top bolt, there is no need for it. BUUUUUUUUUUT saying that, I loosened both bolts too
Hope you can get it!!
Old Dec 3, 2007 | 04:10 PM
App6MT's Avatar
App6MT
Maybe my memory is alittle hazy. My shaft (steering ;p) moved, you could push it up a few inches and out of the way entirely.
Old Dec 3, 2007 | 07:51 PM
track04's Avatar
track04
looks like my steering shaft/u-joint have become one peice.
this sucks, i tried hammering the bottom of the u-joint up but nothing
waiting for a buddy to come over and help tilt the motor to hopefully create enough space
Old Dec 3, 2007 | 11:53 PM
track04's Avatar
track04
just got done,
hardest thing i have ever done in my life
Old Dec 4, 2007 | 05:02 AM
Thumbs up
Originally Posted by track04
just got done,
Congratulations.
Old Dec 4, 2007 | 05:07 AM
citymunky's Avatar
citymunky
just got done,
I bet
Old Dec 4, 2007 | 06:06 AM
singh's Avatar
singh
_______________
Thumbs up
just got done,
Way to go! Feel happy you did this yourself, and saved hundreds of dollars.
Old Dec 4, 2007 | 06:10 AM
gothchick's Avatar
gothchick
Congrats on the install! Welcome to the 'header' family~ Lol! :-)
Old Dec 4, 2007 | 07:39 AM
track04's Avatar
track04
i saved money, but i was forced to drive my summer car in the salt
and to top it off, some oil line blew off and i lost all oil pressure on the way home from work.
anyway, inline6 engines are SOOOOOOOOO much nicer to work on
so much more room
Old Dec 4, 2007 | 08:35 AM
track04's Avatar
track04
anyway,
thanks for all the help. i would never have thought i could get enough clearance by tilting the engine, thank for the internet.
also, my CEL is on. i have the non fowlers on megan test pipes and dc sports headers. any suggestions?
i was also pleased that there is zero drone, and if i drive normally i cant even tell anything has been done to the car. the sound good under power though
