HKS / X02 mod
Old Dec 13, 2007 | 09:38 PM
derek173's Avatar
derek173
Default HKS / X02 mod
Hoping to get my X02 shortly and I was wondering if this doesnt solve my rasp/rattle problem can I add this to the system as another member did ( https://my350z.com/forum/intake-exhaust/313956-sound-clip-headers-testpipes-borla-td-w-magnaflow-x-pipe.html )
Can I place it in the circled area? or where the extensions go (G35 coupe)
Would this work or can i expect some problems?
Thanks
*X02 pic from Invision 350z https://my350z.com/forum/questionable-posts/283137-xo2-true-dual-exhaust-in-stock.html
Old Dec 13, 2007 | 10:06 PM
derek173's Avatar
derek173
Actually isnt the X02 2.5 inch.. so I would need this one?
Old Dec 13, 2007 | 10:08 PM
VN_350z's Avatar
VN_350z
HKS does not have rasp noise.
Old Dec 13, 2007 | 10:12 PM
derek173's Avatar
derek173
I already have rasp
have headers and HFC with stock catback.
Old Dec 13, 2007 | 10:14 PM
soleil's Avatar
soleil
NolaZcc
+1..i had the xo2 and now i have the hks and neither has rasp....they both have different sounds tho..i prefer the hks
Old Dec 13, 2007 | 10:15 PM
soleil's Avatar
soleil
NolaZcc
Originally Posted by derek173
I already have rasp
when i had test pipe and stock exhaust i had rasp like u wouldnt believe but since i've gotten the aftermarket exhaust rasp is nearly if not gone...
rasp is overrated
Old Dec 13, 2007 | 10:18 PM
derek173's Avatar
derek173
rasp is overrated
Mine is more like a tinny rattle
Old Dec 13, 2007 | 10:22 PM
soleil's Avatar
soleil
NolaZcc
its coming from the heat shield around ur y pipe..i had the same problem
Old Dec 13, 2007 | 10:26 PM
derek173's Avatar
derek173
No I messed around with them and they do not touch. It only appears at 2-3k rpm, I cant replicate when parked.... only while driving.
I had it on a lift at a muffler shop and clearance was good. I was reving the engine on the lift as the tech was under the car, but it would not rasp/rattle. I also put header wrap around the y-pipe and cats just in case something was moving around under load
Old Dec 13, 2007 | 10:45 PM
soleil's Avatar
soleil
NolaZcc
def get an aftermarket cat back and u should be good to go..i promise u
Old Dec 13, 2007 | 10:53 PM
derek173's Avatar
derek173
yea I am getting the X02. I am really thinking about adding this muffler since I know the X02 is loud Should also cure rasp on its own.
Old Dec 13, 2007 | 10:56 PM
soleil's Avatar
soleil
NolaZcc
my first exhaust was the turboxs catback and that was extremely loud then i traded a friend for the xo2 and its not that bad at all..keep in mind that i do have test pipes
Old Dec 13, 2007 | 11:01 PM
cbr900son's Avatar
cbr900son
Turbo xs test pipes with XO2 here and no rasp at all. Great sound. Not a bad deal for me since total for the exhaust and testpipes was like 550$ (bought xo2 used)
Old Dec 13, 2007 | 11:13 PM
derek173's Avatar
derek173
so how are your X02s holding up? Any problems with the tips?
Old Dec 14, 2007 | 03:48 AM
meaj82's Avatar
meaj82
Hoping to get my X02 shortly and I was wondering if this doesnt solve my rasp/rattle problem can I add this to the system as another member did ( https://my350z.com/forum/showthread.php?t=313956 )
Thanks
The idea of this is to replace the existing h-pipe. Thats how I did it on my borla. It seems though that this exhaust does not have the problem I had. Judging by what other members have said.
Old Dec 14, 2007 | 04:02 AM
350z2go's Avatar
350z2go
my hks has no rasp at all..
Old Dec 14, 2007 | 05:03 AM
taurran's Avatar
taurran
HKS is too high pitched to me. I like the sound of the X02 exhaust that I've heard in videos.
Old Dec 14, 2007 | 06:07 AM
gothchick's Avatar
gothchick
I put the xpipe on my HKS here. I've also got Kinetix Res Testpipes & DC Headers. I do get a little rasp between 3.5 ~ 4.5... It has less rasp once the engine is fully warmed up and the exhaust gases are at optimal temp.
Attached Thumbnails HKS / X02 mod-dsc01933-1-.jpg
Old Dec 14, 2007 | 08:40 PM
derek173's Avatar
derek173
So do you guys think I could put this on the X02? or would it not work at all?
Old Dec 14, 2007 | 09:09 PM
johnnyblaze007's Avatar
johnnyblaze007
I think it would work but overall the x02 exhaust really isn't that loud by its self. Not sure if with test pipes though.
