Running W/O Cats....
Old Jun 11, 2003 | 04:45 PM
webcarconnection's Avatar
webcarconnection
Default Running W/O Cats....
Anybody running the Z W/O the Cats?
Check Eng. Ligth is on?
Thanks!
Old Jun 11, 2003 | 04:53 PM
scan's Avatar
scan
i was wondering the same ... right now im running w/ the two cats and nothing else from that point back. no muffler, no resonator, just a straight pipe that goes all the way back near the end of the car and shoots downwards the ground
Old Jun 11, 2003 | 06:06 PM
STLZ's Avatar
STLZ
Wouldn't you lose backpresssure which would lose you tq. I thought that running no cats was just an advantage it you had a FI setup and there was no adv for N/A.
Old Jun 11, 2003 | 09:14 PM
webcarconnection
Off topic:
What happen with the Forum, almoust all the replys in the threads are in 0 and when you click in the thread theres a couple of replys
Old Jun 12, 2003 | 05:07 AM
racingdynamcs's Avatar
racingdynamcs
backpreasure is not needed in 3.5L engine
Old Jun 12, 2003 | 10:57 AM
DMONTE's Avatar
DMONTE
What information would make you say that?
Old Jun 12, 2003 | 11:45 AM
racingdynamcs
cause u dont need it...no car engine needs backpreasure....
Old Jun 12, 2003 | 11:47 AM
DMONTE's Avatar
DMONTE
OK
Old Jun 13, 2003 | 07:08 PM
toothlessracer's Avatar
toothlessracer
actually turbo engines do need a little back pressure.
Old Jun 14, 2003 | 03:26 AM
rickl01's Avatar
rickl01
Ummmm....ahhhhh....most "street" engines need backpressure. There is a thing called "internal EGR" that is used for emissions control.
Old Jun 14, 2003 | 05:54 AM
racingdynamcs
who said anything about emmisions?
cars run best with straigh pipes!
Old Jun 18, 2003 | 10:42 AM
SoFl_G's Avatar
SoFl_G
New to this forum, Hello there.
First off, Turbo engines need no backpressure any backpressure at all slows down spooling of the turbos, this from experience on a turbo car. Turbo +backpressure= Bad, sloow spool. We are not talking about between engine and turbo thats a whole different world.
2nd it has been proven that NA motors also do not benefit from backpressure. The old agage of needing backpressure was because engines were not retuned with WB after removing all BP. Once Wide Bands came into use, and testing was done with an uncorked engine, at first there was a torque loss, but once A/F curves were fixed to compensate for the loss of BP, turque improves at least to previous levels and often a few Ft Lbs increase was seen.
I want to hear about how the VQ ECM isn't upset by the loss of the cats. This seems to contradict OBD2 specs, but I like the sound of it, makes uncorking that part of the exhaust easy
Old Jun 18, 2003 | 10:53 AM
racingdynamcs
thx SOFl_B for the back up on this stupid back preasure crap...
Old Jun 18, 2003 | 12:04 PM
SoFl_G's Avatar
SoFl_G
No Prob, old school misconceptions abound, iut will just take time for people to realize that a PROPERLT tuned free flowing exhaust motor will outperform a PROPERLT TUNED motor with some backpressure. Until the availability of relatively cheap WB O2 sensors properly tuned was the problem .
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
