Cat deletes?
Anyone with any insite on the o2 sensors I live in Mineesota and have no issues with emissions so given if i remove the cats do i need to do anything with the sensors. 2nd question anyone know what kind of a difference this will make with aftermarket exhaust as far as it beiong too loud? Any help would be great!
yes you have to retain your o2 sensors. search/look up plug foulers for your 02 engine service light fix and i would suggest intenstive motorsports ss resonated test pipes to take place of your cats.
Originally Posted by gsingh350Z
That's as n00bish as it gets.
https://my350z.com/forum/intake-exhaust/152786-exhaust-nominees.html
thanks dick i realize im a noob but you dont have to be an ***! I figured it out after reading further through the posts sorry to **** you off. I hope everyone realizes how cool you are!
What? i was trying to help, thank you for acknowledging that. jason you really should chill out especially being a newb. You have stumbled onto the best Z forum/community bar none. Do some further reading and enjoy your stay
Bask in my coolness!
Originally Posted by undrgnd
Hey, the thread title is misleading. If this is a contest for being an a$$hole, I need to get in on it. I can be a much bigger dick than anyone here so far, and I have references.
Hey, heres the only answer you need, I did it to my pipes. SIMPLE stuff. its on www. 3 5 0 z - t e c h .com if you need pics to show you what I'm talking about.
go to Oreillys or Advance and get two packs of HELP! plug defoulers (part #42002 i believe). leave 2 of them alone, take the OTHER two and drill them all the way out with a 1/2" hard metal bit (straight down, just bore them out but dont screw up the threads, its easy). a drill press makes life easy but a vice and a hand drill will do (its what I did). take some kind of oil and squirt it in as you drill, a new HARD METAL bit is worth it. you'll burn a wood/metal bit up in no time. screw the 2 STOCK defoulers into each O2 outlet, then screw the two bored out plug defoulers on TOP of the other two stock defoulers. then screw in your O2 sensor and bolt up the pipes. wont throw any lights.
Minnesota and Tennessee's lack of emissions testing FTMFW!
