HELP! Test pipe install !
Old Feb 23, 2008 | 02:29 PM
sbZenth's Avatar
sbZenth
Default HELP! Test pipe install !
I just installed my passanger side AAM test pipe for my 07. the top bolt on the driver side is impossible to get off. i cant get there fwith a breaker bar because of the steering shaft. can someone please help with any suggestions of how to take the damn thing off?
Old Feb 23, 2008 | 02:32 PM
sbZenth's Avatar
sbZenth
Old Feb 23, 2008 | 02:42 PM
sbZenth's Avatar
sbZenth
anyone please ahhh
Old Feb 23, 2008 | 02:51 PM
sbZenth's Avatar
sbZenth
come on im begging you.
Old Feb 23, 2008 | 03:03 PM
WTX350Z's Avatar
WTX350Z
You need extensions and Joints. Make sure to spray some penetrating oil first...and use your muscles.
Old Feb 23, 2008 | 03:05 PM
y0shi's Avatar
y0shi
Spray nut with some WD40, remove driver side intake tube. Get very long extension. Remove nut from the top.
Old Feb 23, 2008 | 03:28 PM
HondaKiller's Avatar
HondaKiller
+1 remove the intake, takes like a 2 foot extension tool.
Old Feb 23, 2008 | 04:18 PM
Mark the coupler and top shaft. Remove the coupler. That should give you more room to work. Put the coupler back the same way that you took it off.
NOTE: Aligning the steering wheel is a pain in the butt.
CAUTION: If you have VDC no not disconnect the steering shaft.
Old Feb 23, 2008 | 06:49 PM
sbZenth's Avatar
sbZenth
Thanks for all the help guys. Im just gonna try every single possible entry point tonight and see if i can take it off. If not, ill just burn it off with a torch tomorrow, most people said that causes the bolt to snap off.
Old Feb 23, 2008 | 06:51 PM
failsafe306's Avatar
failsafe306
You do NOT have to remove the steering knuckle to install test pipes.
You need to have a couple of long extensions and get them from the top of the car, through the engine bay.
Do a search and you will find literally dozens of threads with the same question.
Old Feb 23, 2008 | 09:24 PM
sbZenth's Avatar
sbZenth
yeah. haha i just installed it. thanks a lot everyone. ill get videos tomorrow.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
