BASSANI Exhaust SOUND CLIP - HR
Old Apr 25, 2009 | 08:29 PM
  #121
PCH's Avatar
PCH
Uh...yeah no matter how good it may or may not sound, still will not substitute for quality.
Old Apr 28, 2009 | 06:14 AM
  #122
rotchcrocket04's Avatar
rotchcrocket04
Originally Posted by PCH
Just saw this exhaust in person and i think it is "crap." Poorly built exhaust, looks like someone mickey moused everything. Welds were horrible, i had never seen such a thing! Also, crushed bent? Who does that and who pays a substantial amount of cash for that?
I remember clearly looking over everything when I got mine and the welds were very nicely done (and yes, I've been welding for about 11 years now). I can honestly say I didn't think it was poor build quality in the least
Also, it is most definitely not crush bent piping. It is mandrel bent.
Old Aug 8, 2009 | 12:29 PM
  #123
IsDatIt's Avatar
IsDatIt
Not really....i just got mine yesterday and it was leaking from one of the poorly welded Resonators....
Other than that, it sounds VERY MEAN with my FI Resonated TP's....
kinda raspy at cold though
Oh and my Bassani is the 2nd Generation with Double walled Resonated Tips.....and the Sway bar Rattle Fixed.
Sounds clips in the Future
Old Aug 8, 2009 | 12:44 PM
  #124
Entaille's Avatar
Entaille
I have the 2nd gen as well, make sure the hangers that secure the mufflers are PERFECT, the rear most muffler fits exactly in between the rear bumper support and the bottom of the bumper, and is prone to rattling if not put in perfect position. drove me nuts for a bit, just got it fixed
Old Aug 8, 2009 | 12:46 PM
  #125
Entaille's Avatar
Entaille
I was reviewing the welds yesterday and I was not impressed by them. I thought they were borderline sloppy in some areas. it holds together and the gains are definitely there. sound was the most important factor for me picking this setup
Old Aug 8, 2009 | 12:58 PM
  #126
IsDatIt's Avatar
IsDatIt
i just noticed that thanx for the heads up!! i just fixed it...
yeah the difference from my xo2 to this is like Night and Day!!
better Response at the pedal too!!!
Old Aug 10, 2009 | 10:06 AM
  #127
TShepp's Avatar
TShepp
Anyone using this with turbo or supercharger?? I really want this but dont think its a good choice in case I ever went with a Vortech
Old Aug 10, 2009 | 11:26 AM
  #128
transamnut's Avatar
transamnut
Originally Posted by mistico
Has anyone installed one on a Pre-07 model?
Thanks.
I have it, it sounds just like the video, I still have my Ultimate Racing HFC's on the shelf, waiting to be installed. With stock exhaust manifolds, you WILL NOT be disappointed in the sound or the "butt dyno" gains!!!
Old Aug 10, 2009 | 11:38 AM
  #129
transamnut's Avatar
transamnut
Originally Posted by jammin
anyone of pictures of this exhaust on the car other than powermark's pictures?
Old Aug 10, 2009 | 12:53 PM
  #130
TShepp's Avatar
TShepp
^ HEY, A Wisconsin Z!! I would love to sample this thing in person!
Old Aug 10, 2009 | 07:01 PM
  #131
Toby-22's Avatar
Toby-22
Wat kind of rattling do you get? I have this weird rattle when i deaccelerate. It buzzes/rattles like crazy. And wat should i look for in the hangers?
Old Aug 10, 2009 | 07:38 PM
  #132
pizzato16's Avatar
pizzato16
yeah i know what your talking about man. I had that fixed. They mechanic said the pipe was hitting the rear sway bar. Basically bouncing on it. All he had to do was loosen a couple bolts and rotate the pipe a little so it stopped the bouncing. Get the car on a lift and check out the frames around the exhaust as well as the exhaust itself. look for scrapes or any kind of unfamiliar rubbing marks.
Old Aug 10, 2009 | 08:09 PM
  #133
pizzato16's Avatar
pizzato16
this is mine
Old Aug 10, 2009 | 10:52 PM
  #134
Manjot's Avatar
Manjot
Thanks for the info guys. Mines been rattling too because it's touching the sway bar. Hopefully I can get it fixed soon. =)
Old Aug 11, 2009 | 06:46 AM
  #135
cheshirecat79's Avatar
cheshirecat79
pizzato, is it just the picture or do those tips kind of "flare" at the end compared to the v1? Kinda looks like a trumpet. Not sure if it's some kind of lens distortion or something.
Yeah, mine rattles badly also. Going to try to tackle that within the next couple of weeks.
Old Aug 11, 2009 | 06:52 AM
  #136
Entaille's Avatar
Entaille
just to clarify, the first version of the bassani exhaust rattles against the sway bar. the 2nd revision doesnt suffer the problem, but the mufflers need to be positioned perfectly or it is prone to hit the bumper support or rear bumper.
it's pretty easy to locate if you just crawl under the car and hit the pipes/mufflers
Old Aug 11, 2009 | 07:21 AM
  #137
TShepp's Avatar
TShepp
I was wondering as well...How far do those tips stick out from the bumper? Looks kinda odd
Old Aug 11, 2009 | 07:32 AM
  #138
Darkpath's Avatar
Darkpath
From up top looking down the over the bumper they stick out about 3/4 of an inch when properly positioned.
For Owners:
When cold - check the tightness of the tips both side to side and up and down... Especially the Driver's side tip... On my V2 setup the driver's side loosened slightly and created an annoying rattle at low RPM. Climbing around under there for 10 mins or so and I found it. Vertical tightness seemed fine till I attempted moving it left to right. One push and it dropped 6 inches... Imagine that happening when haulin freight down the Hiway and burning the underside of tip before you could get off the road with it.
Old Aug 11, 2009 | 11:09 AM
  #139
pizzato16's Avatar
pizzato16
thanks for the clarification Enatille and Darkpath.
Looking at the tips close they dont look like they flare.
Old Aug 11, 2009 | 11:21 AM
  #140
Manjot's Avatar
Manjot
JW, do any of you guys have pics of what the exhaust is supposed to look like when positioned correctly? Like underside pics of the piping?
thnx
