Is this rasp?
Old May 4, 2008 | 10:04 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
its not rasp i had the same problem it turned out to be my y pipe
Old May 4, 2008 | 11:05 AM
saberphx's Avatar
saberphx
Maybe a loose heat shield on the y-pipe.
Old Aug 5, 2008 | 04:59 PM
djscotty's Avatar
djscotty
i have the same exact sound, with stock exhaust and test pipes. Any more suggestions?
Old Aug 6, 2008 | 06:00 AM
The Captain's Avatar
The Captain
Go with resonated test pipes / high flow cats or go back to stock cats.
No real miracle solution unless you were using a true dual. Then you could get a resonated X pipe to reduce the rasp.
Old Aug 7, 2008 | 08:04 AM
mistico's Avatar
mistico
I have RESONATED test pipes and have the same exact sound. I don't think it's rasp. The piping isn't touching anything.
If it can be confirmed that it's the stock y-pipe, I'll chnage it but don't want to if the sound will remain.
Sounds like crap when you let off the gas or go WOT. It sounds like an electric spark.
Old Oct 13, 2008 | 05:22 AM
xbuhhx's Avatar
xbuhhx
im having the same exact sounds after install FI 300 cell HFC on my impul exhaust, perhaps getting motordyne's xyz pipe with resonator will elimnate the rasp? i have the impul V pipe and i think thats where the sound is coming from. and I only hear it when i go WOT or around 3.5k rpm and up....
you hear it in this video
http://www.youtube.com/watch?v=t8iHqL5WlsA
z33z_nutz
Sep 23, 2015 07:22 PM
COJ_General
Sep 2, 2005 06:38 AM
NOBI
Apr 3, 2005 09:40 PM
DIE DIE DIE
Feb 10, 2005 11:47 PM
Street Visionz, Inc.
Dec 27, 2004 04:59 AM
