What does the "N1" mean in a lot of exhaust names?
Old May 9, 2008 | 07:04 AM
phreaktor's Avatar
phreaktor
Design Engineer
Question What does the "N1" mean in a lot of exhaust names?
Topspeed, Apexi, RSR, Invidia... What does it mean?
Old May 9, 2008 | 07:21 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Not sure what it's stand for, but N1 is a style.. mabe it's just a type they go by?
Old May 9, 2008 | 07:30 AM
DaytonaRoadster's Avatar
DaytonaRoadster
noisey 1
Old May 9, 2008 | 07:33 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Originally Posted by DaytonaRoadster
noisey 1
Old May 9, 2008 | 07:44 AM
Concave's Avatar
Concave
yea i think its a style, but apexi n1 is known to be the loudest as well
Old May 9, 2008 | 07:48 AM
seekndestroy19's Avatar
seekndestroy19
noisey 1
lol i agree
Old May 9, 2008 | 08:05 AM
phreaktor's Avatar
phreaktor
Design Engineer
Maybe it's that the canisters are at the rear connected directly to the tips?
Old May 9, 2008 | 09:32 AM
Motormouth's Avatar
Motormouth
I think N1 is a race group isn't it? like N1 style or something.
Old May 9, 2008 | 09:36 AM
Spork's Avatar
Spork
N1 is the designing style. IIRC.
Old May 9, 2008 | 08:57 PM
Resolute's Avatar
Resolute
"N1" has become a relatively popular term for a number of tuner companies and their products. It originated, as far as I know, with Nissan. The R32 GT-R had a special, limited production, version of the car known as the N1. It was a lightweight model designed for homologation racing purposes, with no AC and stereo, and reinforced chassis stiffening. Only 220 or so were made, and it was to facilitate and commemorate the success of the new GT-R in Group N racing. Hence, the term "N1", which I have always understood to denote "number one in Group N racing".
The R34 also had a N1 version, which was again light-weight with extra welding to stiffen the chassis, no AC or stereo, lacked ABS and carpet, and sported carbon fiber hood with NACA ducting. Only 45 were made, again for homolagation racing purposes. It's a rare model, and is also the only model of GT-R that Nismo bought back from owners and used to create their limited edition, 500hp Z-Tune GT-R, of which only 20 were made.
The name sounds kinda cool, and the GT-R is a good car to copy from, so it seemed natural that tuner companies would copy the name for parts that are meant to denote racing use or heritage. Even Spoon uses the term "N1" for some of it's more hardcore Honda parts. However, while the term originates from Nissan as a designation for bona-fide racing use in a street-legal application, most of the parts that carry the term today are hardly developed for a racing series or have the development behind them that was originally denoted by the N1 badge on the GT-R.
Will
edit: I was looking for a pic of the N1 GT-R's, and found a wiki article that discusses Nissan's N1 engines. Apparently, the N1 models also had different engines than the regular GT-R's. Here's a copy from Wikipedia on it:
"The N1 engine is the stock R32-R33 Skyline GT-R motor. It was first developed by Nismo for Group A racing purposes. The standard RB26DETT, although known for its durability, proved to require too much maintenance for Group A racing conditions. The N1 engine is built from the standard N1 block. The water cooling channels in the block are enhanced for better flowing. The block, and internal components are also strengthened. The pistons have 1.2 mm (0.047 in) top rings, but otherwise as standard. The connecting rods are the same as standard, and the crankshaft is standard but balanced. The specifications of the camshafts were also improved for power. The N1 engine uses the same parallel twin turbocharger layout but with improved turbochargers. The N1 engine also received an upgraded oil pump and water pump, to improve the cooling and lubrication of the engine. The N1 engine is identified by its 24U number stamped on the block, as opposed to the 05U stamp on standard RB26DETT engines.
The first model of the N1 engine was the R32 N1 engine. It uses a pair of larger turbochargers compared to the standard R32 GT-R. The turbine wheels on the new turbochargers are made from steel, rather than the weaker ceramic used for all standard GT-R models. The R33 N1 engine was slightly revised, with larger turbochargers than the R32 N1 engine, supporting more power if the engine were to be modified.
The R34 N1 engine saw further improvement. The camshafts were slightly improved for even more potential power, the turbochargers were about the same size as the R32 N1 turbochargers, except now they use ball bearing technology, which operates much more quickly than any other model used.
The most improved N1 engine is the R34 Nür engine. It is based on the R34 N1 engine. The camshafts were further improved for power, and the crankshaft was further balanced for higher engine speed. There were 1000 Nür engines made by Nissan and all were used in the R34 V-spec II Nür, and R34 M-spec Nür models. They were advertised as making the same 280 PS (276 hp) as the standard model, but with the lighter engine parts, and more efficient turbochargers, the engine would make closer to 350 hp (260 kW)."
Old May 10, 2008 | 05:04 AM
phreaktor's Avatar
phreaktor
Design Engineer
Will
Jesus...
sales@czp
Sep 23, 2019 03:30 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
_bit
Oct 2, 2015 07:49 AM
