Getting a Pop Charger! Few questions...
Old May 25, 2008 | 03:41 AM
Big Tav's Avatar
Big Tav
Default Getting a Pop Charger! Few questions...
Hi guys, I think I am going to go a popcharger. From what I have read they all make Intake mods only make small gains so I might as well go with the one that is cheapest (but still good quality) and makes the best noise!
I have 4 questions first.
1. I think in Australia you can get a defect/fine if the pod filter is exposed in the engine bay. Is it possible to extend the heat shield to cover the Pod or will it ruin how it works? The chances of me getting booked for it are very slim though. Thoughts?
2. Does it just go on the end of the stock tubing or do you get another larger diameter tube with the popcharger? If I was to buy a better tube (for looks and airflow) what should I get? Any photo's of suggestions?
3. How often do I have to clean the filter in normal conditions? Is it hard to get out?
4. Should I install myself or get it done professionally? How hard is it?
Thanks!
Old May 25, 2008 | 07:21 AM
twitch579's Avatar
twitch579
Old May 25, 2008 | 07:44 AM
06dieselZ's Avatar
06dieselZ
Thanks!
1. It's exposed like that.
2.It goes on the stock Z-tube.
3.I have never cleaned mine in 10,000 miles maybe i should. lol
4.DIY. It is really easy takes at most 30 min
Old May 25, 2008 | 08:00 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
^ 10,000?? shieeett... yeah i definitely need to clean mine .. its been 20K +
Old May 25, 2008 | 08:03 AM
haeshik's Avatar
haeshik
take it to shop? puhahahaah you gotta be kidding me
Old May 25, 2008 | 05:46 PM
Escobar's Avatar
Escobar
just type in popcharger and read the 1000s of threads, all those questions have been addressed.
Old May 25, 2008 | 08:25 PM
Besides these 239 threads this is the first I have heard about this pop charger thing.
Old May 26, 2008 | 01:53 AM
Big Tav's Avatar
Big Tav
Thanks for the flame post and I did search first. I bet there are none about whether they are legal in NSW Australia. I know that is the way they come. I want the sound of it but I don't want a defect either.
Old May 27, 2008 | 03:58 PM
gothchick's Avatar
gothchick
heat soak ftl
Old May 27, 2008 | 08:54 PM
Escobar's Avatar
Escobar
I think you will be ok, it is so easy to switch back to stock if you need to pass inspection or something. Why would it be illegal to have an aftermarket intake?
Old May 28, 2008 | 05:21 AM
Big Tav's Avatar
Big Tav
In Australia it is illegal to have an exposed filter not in an enclosed box. I love the sounds of a Pop but I may have to go Stillen or Mishimoto because of it.
Old May 28, 2008 | 05:24 AM
blasian's Avatar
blasian
I believe the Stillen is very similar to the PC with a better heat shield.
Old May 28, 2008 | 05:32 AM
If you need the filter in a box look at the K&N Typhoon Air Intake.
Old May 28, 2008 | 05:37 AM
nyguy4u's Avatar
nyguy4u
I haven't yet installed mine either, but in really quickly reading the paper that came with it, I need to drill somewhere to install the heat shield? Is that true?
Old May 28, 2008 | 06:57 AM
raf84ny's Avatar
raf84ny
^^^ You have to make two little holes where the heat shield attaches to the snorkel - not a big deal.
"You'll then need to drill or punch 2 holes in the plastic snorkel aligned with the screw holes in the heat shield."
Old May 30, 2008 | 11:51 AM
Steve-O Z33's Avatar
Steve-O Z33
It's a self-tapping screw, so you don't have to drill. It's a lot easier to drill, though. That's some thick plastic and there is no room to work with unless you have small hands and a small screwdriver.
Old May 30, 2008 | 05:08 PM
Swiffer's Avatar
Swiffer
^ in other words, drill it
07ZEKE
Aug 23, 2021 09:15 PM
_bit
Oct 2, 2015 07:49 AM
B Esquire
Sep 24, 2015 07:52 AM
