Motordyne XYZ-Pipe (Pilot Production)
Old Aug 14, 2008 | 07:30 AM
  #441
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
And yes, the resonator module goes slightly lower than stock. ~3/4"
...on a different subject. Who here still has their edit button? I don't.
Old Aug 14, 2008 | 07:55 AM
  #442
Motormouth's Avatar
Motormouth
I just found out mine is back. it wasn't there yesterday! I can also delete again!
Old Aug 14, 2008 | 09:13 AM
  #443
ginobetterfly's Avatar
ginobetterfly
Originally Posted by Motormouth
I don't know if it has been asked, but have you taken into account ground clearance for lowered cars? the placement of the 'cat' section on the Y pipe seems like it could hang down a little lower (not 'hang' but the size of the canister might stick out) than the frame. and that is a section I always rub.
im pretty low on coilovers (pretty much zero fender gap) and i have no problems with my XYZ and resonator...
Old Aug 14, 2008 | 12:06 PM
  #444
Hydrazine's Avatar
Hydrazine
Default Dual Exhaust
Shockwave Dual Exhaust
The one is actually a little quieter than the single.
The Harakiri Ti and stainless mufflers are next!
Old Aug 14, 2008 | 12:14 PM
  #445
Hydrazine's Avatar
Hydrazine
Default TDX Shockwave
This is a picture of the XYZ-Pipe being used in the True Dual "X" configuration.
Old Aug 14, 2008 | 12:40 PM
  #446
A.H's Avatar
A.H
I'm sorry but from that picture of the "true" dual when its on the car it looks like some very low quality ricer exhaust that someone built in their garage and those single wall microphone tips only add to this image. Just imo
Old Aug 14, 2008 | 12:57 PM
  #447
invazn's Avatar
invazn
function over form? i think it was mentioned that they act as diffusers. cant wait for the ti tips!
Old Aug 14, 2008 | 01:26 PM
  #448
Get_Zwole's Avatar
Get_Zwole
tru that the TI tips will really make it stand out i cant wait to see.
Old Aug 14, 2008 | 02:12 PM
  #449
06dieselZ's Avatar
06dieselZ
DOT.
Looks like trombones
Old Aug 14, 2008 | 03:23 PM
  #450
Frostydc4's Avatar
Frostydc4
Thumbs up
Originally Posted by Hydrazine
The focus of the Motordyne Iso Thermal Intake is all about preventing heat soak weather you are moving fast or stageing at the 1/4 mile line.
Awesome. I cant wait for this and will definately be buying this (can I be a tester? )
I have also found out while staging in 95-110 deg. temps that the ECU defaults to a more conservative timing map when the MAF gets really hot.
Old Aug 14, 2008 | 03:24 PM
  #451
drive4fun's Avatar
drive4fun
I'm a little disappointed to say that the exhaust does look a little cheap once on the car. The pictures of the exhaust itself look much better. What size diameter tips are those? Hopefully it's just the pictures because I do love how the shockwave sounds.
Any other shots a little further away from the car? Different Angles?
Can't wait to see the Ti's...
Thanks,
~Adam
Old Aug 14, 2008 | 06:09 PM
  #452
Hydrazine's Avatar
Hydrazine
Yes, the diffusers are about function over form. Other looks are currently being made.
Old Aug 14, 2008 | 06:52 PM
  #453
turborevdboy11's Avatar
turborevdboy11
looks bad ***! Tony installed the exhaust today and wow it sounds like a beast...high rpms the car is def. and animal...the second I turned the car on my girl looked at me and just made a face lol...I loved it! I just bought a body kit and I hope the muffler fits with the rear bumper...it has that section that forms over where the muffler would be...in my case a big *** diffuser! But it sounds so nice with the berk hfc's...Very pleased with the shockwave...Looking forward to more motordyne products...Also will most likely upgrade to your dual shockwave set up later...along with any other part you make...you need a tester or a rep here in hawaii Im your man!!
Old Aug 14, 2008 | 07:07 PM
  #454
Hydrazine's Avatar
Hydrazine
Right on Ian! Thanks.
It sounds awesome on stock cats and seriously wicked on test pipes.
Can you get a sound clip with the Berks once its had a little time to break in?
If you havn't broken it in already, take notice of the change of sound during break in. It will smooth out and become more progressive after two to three hours of use.
Old Aug 14, 2008 | 07:10 PM
  #455
turborevdboy11
Just keeps getting better! yeah ill get some vids up soon...
Old Aug 14, 2008 | 07:36 PM
  #456
jdemos's Avatar
jdemos
Forgive me if I missed this in the previous 20+ pages
Tony how much power has the xyz pipe dynoed over conventional y pipes?
Which of your setups will make the most power?
Diameter of the exhausts?
Again sorry if I missed this info earlier.
Old Aug 14, 2008 | 07:51 PM
  #457
A.H's Avatar
A.H
Why is there a weld in the middle of the tips?
Old Aug 14, 2008 | 08:24 PM
  #458
Hydrazine's Avatar
Hydrazine
Not much more but I wanted to let the details come out with an independant dyno. Dynoing against the JIC would make a particularly good comparison. For both power and sound.
It was supposed to happen at MRC last Monday or Tuesday but neither I or Plumpzz is able to get in touch with them.
Its all delivered and ready to dyno.
Old Aug 14, 2008 | 08:30 PM
  #459
Hydrazine's Avatar
Hydrazine
The diffusers are too large in diameter (5") to be flared from 3" tube and must be made of rolled sheet stock.
The outside is polished to the point where smooth and no longer visible. The inside is visible, but it won't be after a good amount of driving. The inside will become black like any other tip.
Old Aug 15, 2008 | 05:27 AM
  #460
twin001's Avatar
twin001
The great thing that Tony has done is create a modular exhaust system. With that said, it is possible to go from a truly streetable VQ exhuast (from Motordyne) to a very efficient track-ready Shockwave exhuast in under 5 minutes (proven by Tony on video). Like others said, function over form.
Good job Tony, the Shockwave and TD look great. I'm still holding out for the VQ for my G35! As soon as it's ready you know what to do
