Motordyne XYZ-Pipe (Pilot Production)
Old Aug 13, 2008 | 07:38 AM
  #421
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
This picture is grainy but it shows the effect of inlet temperature Vs HP.
This plot is the reason for keeping the focus of intake design on thermal management.
  #422
Hydrazine's Avatar
Hydrazine
Old Aug 13, 2008 | 10:56 AM
  #423
rcdash's Avatar
rcdash
Originally Posted by Hydrazine
Glex, you are FI right?
I have something much better for your application.
5" FI cat converters.
Pressure reduction is everything to FI.
Hopefully you can move the cats back to reduce pressure right after the turbo. I had FP create custom cats, 3.5" inlet/outlet, 4.25" core 200 cell metallic. Still lost a solid 40 whp vs. 3.5" test pipes.
If you can come up with a quiet exhaust that matches my custom cats + evoTT performance wise, then I'm ready to give it a shot. Good luck!
Old Aug 13, 2008 | 02:28 PM
  #424
jammin's Avatar
jammin
The focus of the Motordyne Iso Thermal Intake is all about preventing heat soak weather you are moving fast or stageing at the 1/4 mile line.
will this intake sound stockish and be quiet? or will it sound like any other aftermarket intake?
Old Aug 13, 2008 | 02:31 PM
  #425
Get_Zwole's Avatar
Get_Zwole
i hope its loud i love being able to hear the engine roar and not all exhaust.
Old Aug 13, 2008 | 03:13 PM
  #426
Diesel350's Avatar
Diesel350
That's the problem with aftermarket intakes on this car.
There isn't really much to be gained fluidynamiclly but there are significant documentable losses associated with heat soak. Even the stock box gets quite hot when the hood is closed and the car is motionless. When this happens the MAF gets hot and causes the ECU to pull timing.
This causes about a 5-10 HP loss for the first several seconds after launching. (I'll post the Temperature Vs HP dynos.)
IMO the stock air box is the best all around air intake available for the Z. ...That is until the Motordyne Iso Thermal Intake comes out.
So I take it you will come out with something to lower the intake temperature in the airbox?
Old Aug 13, 2008 | 03:22 PM
  #427
warmmilk's Avatar
warmmilk
nvm, reading pwns me
Old Aug 13, 2008 | 03:37 PM
  #428
jammin's Avatar
jammin
me too lol
Old Aug 13, 2008 | 03:58 PM
  #429
drive4fun's Avatar
drive4fun
It's only a matter of time where everyone will have all their mods from Motordyne.
Any other modifications that we should know about?
What kind of gains can we see with the Iso Thermal Intake?
Old Aug 13, 2008 | 04:02 PM
  #430
drive4fun's Avatar
drive4fun
Also waiting on the dual exhaust Pictures..
Old Aug 13, 2008 | 09:08 PM
  #431
Hydrazine's Avatar
Hydrazine
I will start a thread on the intake later.
Meanwhile, does anybody know if/when MRC is open for business?
I can't get hold of anybody there.
Old Aug 13, 2008 | 11:32 PM
  #432
Frostydc4's Avatar
Frostydc4
Damn, that shockwave with the testpipes sounds awesome
Old Aug 14, 2008 | 01:32 AM
  #433
turborevdboy11's Avatar
turborevdboy11
just got my shockwave and xyz! Can't wait to install tomorrow!
Old Aug 14, 2008 | 04:30 AM
  #434
chopperman's Avatar
chopperman
What does that graph represent?
Old Aug 14, 2008 | 04:43 AM
  #435
tranceformer95's Avatar
tranceformer95
Usually around 10ish someone is there. And Julian usually takes off around 5ish for his other job. Have you tried his cellphone?
Old Aug 14, 2008 | 05:23 AM
  #436
Hydrazine's Avatar
Hydrazine
Its a plot showing Air intake temperature Vs HP.
As shown in the plots, air intake temperature has a very large effect on engine power.
This is why your car feels so much snappier on a cold day. It is also why air intakes should be completely sealed against induction of hot air from the engine compartment.
Old Aug 14, 2008 | 05:29 AM
  #437
Hydrazine's Avatar
Hydrazine
No. Can you PM it to me?
Thanks
Old Aug 14, 2008 | 06:13 AM
  #438
Hydrazine's Avatar
Hydrazine
I know I'm biased, but yes, it sounds awesome.
Old Aug 14, 2008 | 06:42 AM
  #439
Motormouth's Avatar
Motormouth
I don't know if it has been asked, but have you taken into account ground clearance for lowered cars? the placement of the 'cat' section on the Y pipe seems like it could hang down a little lower (not 'hang' but the size of the canister might stick out) than the frame. and that is a section I always rub.
Old Aug 14, 2008 | 07:13 AM
  #440
Hydrazine's Avatar
Hydrazine
Yes, that was adressed early on.
It is merged up as high as possible to provide the greatest possible clearance. When used in the straight Y pipe configuration, its actually higher than stock.
