Motordyne XYZ-Pipe (Pilot Production)
Old Aug 27, 2008 | 02:17 PM
  #541
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Im not really attacted to the sound in those vids like I was the 1 vid the guy had test pipes. Sounds just like a single exhaust set up. I wanna see DE non rev up with test pipes the full single y pipe and all, popcharger and maybe a plenum spacer and see what that makes. IDK if its just me but seems those HFCs are holding u back power and sound wise
Old Aug 27, 2008 | 03:19 PM
  #542
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Are you referring to the White Z?
Old Aug 27, 2008 | 03:36 PM
  #543
2004Black350z
Exhaust Whore
yes sir Tony
Old Aug 27, 2008 | 04:00 PM
  #544
Hydrazine's Avatar
Hydrazine
Yes, thoes were Motordyne test pipes in the white Z. And they don't sound like most other test pipes because they arent like any other test pipe. The unresonated MD test pipes are probably the loudest, nastiest test pipes ever made for the Z.
They are brighter, louder, make a lil more power and have a greater tendancy to rasp.
The rasp still doesn't come through on the resonated XYZ and Shockwave exhaust but then again different exhaust systems will have different sensitivities to rasp.
When used on the resonated XYZ and Shockwave, it really lives up to the name Shockwave.
PS - I actually liked the sound of Plumpzz's system with the cats.
To me it sounds like a nice balance of exotic sound with moderated loudness.
PPS - everybody likes something different so I'll also offer a more normal resonated test pipe too.
Old Aug 27, 2008 | 07:51 PM
  #545
plumpzz's Avatar
plumpzz
The setup i had sounded nice. It didnt rasp. This weekend i'm going to swap the rear end with my JIC setup and see what it sounds like. I'm expected the rassp I had to go away since the resonator in the Y pipe is going to cover it up.
Old Aug 28, 2008 | 12:06 AM
  #546
turborevdboy11's Avatar
turborevdboy11
when I get my car back from the shop(lip kit) Ill get a vid of my 04' roadster with berk hfc's, 5/16 iso thermal spacer, pop charger and xyz merge collector with the shock wave exhaust...it sounds pretty mean... I need to get it dyno'd but my butt dyno tells me I gained some power through out the powerband...low mid and topend are all better for sure...Everybody likes the exhaust here in hawaii...you do lose the vq sound but the md sounds nice!
Old Aug 28, 2008 | 07:20 PM
  #547
warmmilk's Avatar
warmmilk
Hydrazine.
so are there any updates on the other exhaust add on that will work on any exhaust on any car that adds 40 tq that you told us about along time ago?
Old Aug 28, 2008 | 07:27 PM
  #548
A.H's Avatar
A.H
I heard that "myth" only gained like 4wtq or something and it's a total hoax
Old Aug 28, 2008 | 07:37 PM
  #549
Hydrazine's Avatar
Hydrazine
Originally Posted by warmmilk
Hydrazine.
Its in the patent process. I'm not doing anything with it until the patent atty. gives me the go.
Old Aug 28, 2008 | 07:43 PM
  #550
A.H's Avatar
A.H
Don't patents take like a couple years to finalize though?
Old Aug 28, 2008 | 07:51 PM
  #551
Hydrazine's Avatar
Hydrazine
Unfortunatly yes.
But that doesn't necessarily mean I can't start before an actual grant.
There is a more to it than just a large increase of power. Seriously, I need to present this to OEM before it is shown anywhere else.
Old Aug 28, 2008 | 08:51 PM
  #552
warmmilk's Avatar
warmmilk
so we're quite literally years away before we can get our grubby little hands on that?
Old Aug 28, 2008 | 09:31 PM
  #553
scmtkings4's Avatar
scmtkings4
Ok so i know that the resonator helps with rasp. but it also quiets down the exhaust, which turns me off.
BUt the straight section seems to be alright. But how does the straight help with rasp? Does it help at all? Also, has there been any tests for whp increase with the straight section
and lastly, im thinking about switching out my nismo y pipe because of the crappy flex sections. How are the flex joints with the xyz and will it be able to accomodate all the movement from the hfc?
Old Aug 28, 2008 | 09:55 PM
  #554
Hydrazine's Avatar
Hydrazine
The resonated XYZ doesn't really do to much to reduce overall loudness. Its mostly about rasp and high frequency reduction. Its much too small to be a muffler. Its about changing the tone of the exhaust.
The straight section will sound a little different too. It rasps a lil less than the Nismo Ypipe simply because it merges sooner... and that affects the sound quality too.
I can't say about other after market cats though.
And yes, they dyno very similarly.
Old Aug 28, 2008 | 09:56 PM
  #555
Hydrazine's Avatar
Hydrazine
Sorry, this is most likely true.
Old Aug 30, 2008 | 09:17 PM
  #556
terrasmak's Avatar
So when does the next muffler option become available???
Old Aug 30, 2008 | 09:33 PM
  #557
Hydrazine's Avatar
Hydrazine
Dual or single?
Old Aug 31, 2008 | 07:30 AM
  #558
Laino's Avatar
Laino
this may have been answered already but, do you plan on making test pipes with the same high quality resonators? That would be sweet.. and make them in the $250 range, Id buy
Old Aug 31, 2008 | 07:42 AM
  #559
Hydrazine's Avatar
Hydrazine
Yes, MD will be producing resonated and non-resonated test pipes.
Old Aug 31, 2008 | 09:07 AM
  #560
scmtkings4's Avatar
scmtkings4
damn i wish i could get test pipes. emissions test every year.
