Nismo exhaust w/ mods **rev and launch videos inside**
Old Oct 29, 2008 | 07:14 PM
Z You Later's Avatar
Z You Later
Default Nismo exhaust w/ mods **rev and launch videos inside**
well i finally got my video made of my exhaust system...enjoy!!
free revving: http://www.youtube.com/watch?v=bBRlvcljIXw
launch: http://www.youtube.com/watch?v=lN0KjUMXkW8
Old Oct 29, 2008 | 09:36 PM
singh's Avatar
singh
_______________
Not bad..
Get sound clips of the car launching. I want to hear it under load..
Old Oct 30, 2008 | 12:07 AM
Allen331's Avatar
Allen331
Car sounds awesome..
However, if I remember correctly, the hissing you hear is the mixture of different temperature exhaust gases mixing with each other.
Old Oct 30, 2008 | 09:01 AM
Z You Later
Originally Posted by gsingh350Z
Not bad..
I have been looking for a road to do it on in this area but it's hard cause either the road has traffic on it or there is construction going on somewhere so the road is littered with rocks...when i find a good road to do it i will definitely make one because the sound under load is just amazing!
thanks! and that could be correct too, but i do know the flex joints do expand under the pressure and compress back and make some noise
Old Oct 30, 2008 | 01:08 PM
Z You Later
bump...launch video added...sound quality isn't the best because it was windy and i had to hide it off to the side behind a pole
Old Oct 30, 2008 | 03:50 PM
singh's Avatar
singh
_______________
Sounds sweet dude!
Old Oct 30, 2008 | 06:19 PM
Get_Zwole's Avatar
Get_Zwole
sounds awesome love it.
Old Oct 30, 2008 | 07:53 PM
Z You Later
thanks guys! i think i've driven over 300 miles since putting the rest of the exhaust system on last week...i just can't get over how good it sounds, MUCH better sounding in person!
Old Oct 31, 2008 | 07:35 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Sounds like mine =) Awsome! haha
Old Oct 31, 2008 | 07:43 AM
UofA350Z's Avatar
UofA350Z
Nice, I love my Nismo exhaust. What are your other mods?
Old Oct 31, 2008 | 08:36 AM
Z You Later
intake mods are:
JWT popcharger
Motordyne Iso-thermal plenum spacer
Megan V2 test pipes
nismo exhaust
for test pipes i recommend the V2 cause not only do they have flex joints, but a HUGE o2 bung and i have had no issues with a CEL code...i also have an ingalls torque damper to keep the engine from torqueing over and stressing the TPs and tranny
Old Oct 31, 2008 | 10:04 AM
OldDirty Z33's Avatar
OldDirty Z33
I would have took your video camera
Old Oct 31, 2008 | 12:31 PM
Z You Later
haha, it's funny you said that cause i was worried that was going to happen since a few cars drove right past it...good thing it was hidden good enough to where people didn't notice it or else that would have sucked!
Old Oct 31, 2008 | 01:08 PM
twin001's Avatar
twin001
Does your setup drone in the cabin? I had the Nismo y-back, Megan TP's, and the Motordyne XYZ pipe w/ cat section in and it droned like crazy. I had it on for a half a day and took the Nismo y-back off and the Megan TP's off. I put the OEM cats and OEM midpipe/muffler back on. I'm going to see how the Nismo sounds with the stock cats this weekend. I think part of my issue is that I have a G35 and I had the 8" extension custom made. Midas screwed that up pretty bad. First they made it 7.5" and my midpipe made major contact with the crossmember. This caused some crazy vibrations in the car (maybe caused some of the drone too?). Second, the welds on the flange were so big that the bolt head wouldn't even touch the flange. I think that was causing an exhaust leak.
Old Oct 31, 2008 | 01:38 PM
Z You Later
the drone is only loud when accelerating or going WOT...cruising isn't bad at all around 2-2,500k rpm but above this is when it kicks in but like i said it's not bad until you accelerate or punch it, then it turns heads! :P it happens a lot to me when i'm just driving and someone next to me revs there engine so i down shift and the engine comes to life and screams back at them!! haha, i get many mixed impressions from it cause you can tell they weren't expecting it
Old Oct 31, 2008 | 08:51 PM
singh's Avatar
singh
_______________
Originally Posted by Z You Later
intake mods are:
JWT popcharger
Megan V2 test pipes
nismo exhaust
I like the idea of the flex joints built in the test pipe. I wonder why more companies don't utilize flex joints in their test pipes..
These test pipes look like a good bargain. I will tell my cousin to buy them for his stock 04 G35.
Old Oct 31, 2008 | 08:54 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i think Because Y-pipe's flex joint r enough.
Old Nov 1, 2008 | 09:50 AM
Z You Later
well sometimes that can be a hit or miss..especially since the VQ tends to crack TPs no matter what brand they are, some more than others, but the flex joint is definitely a step in the right direction so it's no longer "when they will crack" but more of "IF they will crack"
Old Nov 1, 2008 | 10:34 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Tell me what brand cracks TP or hfc, expect nismo/injen TD. My AAM y-pipe's flex joint is very flexble than nismo's, i don't see why need extra flex joint on TP. ( megan's addin flex joint on TP idea wasn't very succesful on the market anyway)
Justin100
Nov 29, 2015 03:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
Stevo Z
Oct 3, 2015 09:14 PM
torchkc
Sep 11, 2015 08:26 PM
