Butt-dyno sez I restored 20hp...
Old Nov 29, 2008 | 10:08 PM
350Zdj's Avatar
350Zdj
Default Butt-dyno sez I restored 20hp...
...Just by replacing my leaking Y-Pipe with a new one!
I bought the Z earlier this year and I guess I was too noob to realize my Y-pipe was having some leak until a friend told me so.
No wonder the revs kept dipping every time i release the accelerator. i always thought it was the CAI messing up the a/f or something. Some idiotic shop said it might be the fuel pump.
Last week, I ran into a monstrous hump that tore the already-fcked up Y-pipe, causing the Z to sound like a friggin Harley D chopper. I was forced to buy a new one.
The Z never felt so much lighter and a lot smoother to drive after the install. Now, there's always a voice that keeps on telling me to squeeze the damn pedal and feel the powah!
So is it always the y-pipe that hits the ground first?
Old Nov 29, 2008 | 10:12 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Old Nov 29, 2008 | 11:13 PM
Sergio07350Z's Avatar
Sergio07350Z
are you sure that it wasn't a fart that felt like 20HP from your ****?
Old Nov 29, 2008 | 11:40 PM
350Zdj's Avatar
350Zdj
^that would've been the nitrous-boost dude!
Old Nov 29, 2008 | 11:42 PM
Sergio07350Z
LMFAO^
Old Nov 30, 2008 | 03:02 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Old Nov 30, 2008 | 09:09 PM
350Zdj's Avatar
350Zdj
^LOL!!!
I guess it's always the Y-pipe that rubs the ground first whenever the Z decides to scrape the asphalt. So i went for the used stock one. barely scratched too.
Old Dec 1, 2008 | 06:24 AM
Get_Zwole's Avatar
Get_Zwole
Originally Posted by 2004Black350z
Old Dec 8, 2008 | 06:07 AM
Tac-M's Avatar
Tac-M
i am a noob, can someone explain the leak theory? why does it loose power ?
Old Dec 14, 2008 | 05:34 PM
Ziggyrama's Avatar
Ziggyrama
A well performing exhaust is a well flowing exhaust. Good flow is critical to optimal performance. When gases have turbulence in the stream, they loose velocity and therefore slow down the flow. When you get a leak in the exhaust, that is exactly what happens: significant disruption in the flow. Also, a leak disrupts temps which also help the exhaust flow better. The idea is to keep the heat in. Leaks disrupt that which contributes to the problem.
To summarize, best exhaust is the one that flows best at a particular point in time. There is no one "best exhaust" because one size does not fit all. To achieve best flow, you need correct diameter matched to the volume of gases and ability to keep the heat in to promote velocity. Hope that helps.
Old Dec 15, 2008 | 05:34 AM
Tac-M's Avatar
Tac-M
thanks ! i think i have some issues with that.... need to take a trip to a friendly lift....
Old Dec 15, 2008 | 07:42 AM
THe Emperor's Avatar
THe Emperor
Yeah my Y pipe is really messed up as well and I seem to have another leak further back too. I'm going aftermarket.
Old Dec 15, 2008 | 05:35 PM
robbinsj's Avatar
robbinsj
yea if you have to fix then its time to get aftermarket
Old Dec 15, 2008 | 09:44 PM
THe Emperor
Yeah I don't think it's a good sign that my Y pipe is all shredded up.
Old Dec 15, 2008 | 09:47 PM
Nexx's Avatar
Nexx
20whp eh? your butt dyno must based off a dynocom or a inflated mustang dyno. get someone with a dynojet or dynodynamics butt dyno to re-dyno your car. and dont tell me that you used some sort of dynojet correction because we all know that all butt dynos are different.
Alang
Feb 4, 2004 08:33 PM
fdao
Aug 11, 2003 03:51 PM
elektrik_juggernaut
Jun 11, 2003 11:49 PM
slaponte
May 15, 2003 09:37 AM
