Exhaust setup bothering me
Old Apr 28, 2009 | 02:49 PM
AUS10TAT10US's Avatar
AUS10TAT10US
Default Exhaust setup bothering me
My setup is Greddy Evo2 exhaust, Megan test pipes, DC headers, Spacer, K&N Drop-in. I recently modified the greddy to make it a true true dual, namely I had the bottleneck cut off and replaced it with two straight pipes.
The problem is, although the sound is deeper, there is a lot of rasp after 3k. Before I had headers, the test pipes and greddy sounded great, now it sounds kinda ricey and is really bothering me. I had hoped that modifying the exhaust to two straight pipes would fix most of the sound, but it didn't.
I'm not sure what to do to fix this as HFC could decrease the sound but is pricey, header removal is also too pricey, and exhaust switching is too. So my only other option is to remove the test pipes and put the stock cats back on.
Opinions? Thanks.
Old Apr 28, 2009 | 02:59 PM
0jiggy0's Avatar
0jiggy0
i dont know how the greddy is setup but when you say true duel did you get rid of the X pipe and make it a pure dual exhaust? Why would you do that? Thats why it sounds terrible.
marcus321's Avatar
marcus321
Opinions? Thanks.
maybe do what what borla owners are doing and install a magnaflow xpipe?
Last edited by marcus321; Apr 28, 2009 at 03:15 PM. Reason: forgot to add that it is a magnaflow xpipe
Old Apr 28, 2009 | 03:00 PM
AUS10TAT10US
The thing is, it was already sounding bad before I changed to pure dual. Had the same rasp above 3k. Now it's just a deeper rasp.
Old Apr 28, 2009 | 03:44 PM
leg killa's Avatar
leg killa
thats sucks man..it seems like either way your going to spend some money...did you do all the work yourself?
Old Apr 28, 2009 | 07:06 PM
67ZNISMO's Avatar
67ZNISMO
If you're having problems before you even touched the xpipe then your rasp is originating from the test pipes bro...
Old Apr 28, 2009 | 07:55 PM
Get_Zwole's Avatar
Get_Zwole
^^ yup more then likely you will just about always have a little rasp i guess it just doesnt bother me much.
Old Apr 28, 2009 | 10:47 PM
Thermal1's Avatar
Thermal1
So you have headers, test pipes, and a hacked up pure dual exhaust and you wonder why you have rasp?
Are you kidding?
Now for the common sense part: Add a resonator and it will help a little. Are the Megan test pipes resonated? If not, throw them in the garbage and get resonated TPs or get HFCs.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
