exhaust problem question
Old Aug 11, 2009 | 12:32 AM
sillyme's Avatar
sillyme
Default exhaust problem question
I just put on my topspeed (intense power) y pipe and AAM 3" single back exhaust. I had to take out the rear lower brace to make it fit or it'll hit it. Is that a common issue? Is there a brace that replace the stock brace to make it stiff again?
Old Aug 11, 2009 | 12:40 AM
Whaty is a rear lower brace? Photos?
Old Aug 11, 2009 | 12:49 AM
sillyme's Avatar
sillyme
Default no photo
the one that is connecting across the lower frame rails. kind of a wide u shape, black brace. right where the y pipe connects to the rear exhaust.
Old Aug 11, 2009 | 04:37 AM
sweets2k's Avatar
sweets2k
Lots of people remove that brace. I researched it and found that is common with aftermarket exhaust setups.
Old Aug 11, 2009 | 04:56 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Aug 11, 2009 | 01:16 PM
sillyme's Avatar
sillyme
Default thanks
but is the brace needed or recommended?
Old Aug 11, 2009 | 02:23 PM
homErx55's Avatar
homErx55
um.. im sure that brace is there for a specific reason..
i had that problem with my TurboXS exhaust, but i just built bracket to hold the exhaust up
Old Oct 7, 2009 | 07:32 PM
sillyme's Avatar
sillyme
Default more problems
just started driving the car. the exhaust hangs about an 2 inches too low. everything fits alright except the brace being gone but my car is pretty low and now the exhaust is scraping on things i normally wouldn't need to worry about. probably get the exhaust rewelded and have it tucked higher.
this info i'm sharing is for anyone that needs some info on parts. btw, exhaust does sound nice.
Old Oct 21, 2009 | 07:50 AM
Elan's Avatar
Elan
You can put a piece of rubber between the pipe and the brace. My friend did that with his TurboXS pipes and there hasn't been a problem since.
Old Oct 21, 2009 | 08:18 AM
terrasmak's Avatar
Just get a Motordyne Y pipe and call it good. No clearance problems, it actually clears by about 2 inches.
Vigman
Nov 17, 2015 04:34 AM
Nicky R
Sep 20, 2015 01:05 PM
NYGiants0186
Sep 8, 2015 10:37 AM
