Gruppe M Carbon intake installed
Old Oct 20, 2003 | 06:12 AM
ZEROLIFT's Avatar
ZEROLIFT
i dyno'd the car with the veilside exhaust and the gruppe m intake. this dyno was new and i am not 100% feeling like this was acurate. it was also a mustange dyno which is different. i have never dyno'd on one before. these dynos are meant for tunning instead of getting HP numbers. they are said to be 15% off from a normal dyno.
my numbers were 251hp @wheels
and then i ran the 1/4 on the dyno (which was wayyyy tooo funn)
and i ran a 13.3 @106
if this HP number seems low...let me know.
thanks,
john
Old Oct 20, 2003 | 06:54 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
way low
Old Oct 20, 2003 | 07:04 AM
Rxramon's Avatar
Rxramon
Charter Member #45
Low - unless this mod causes a 100 hp decrease... which i doubt
Old Oct 20, 2003 | 07:07 AM
ZEROLIFT's Avatar
ZEROLIFT
ok i am going to go to a dynojet then and do it the way i am used to. i figured i wasted my money on that new dyno. they have not had enough experience with the dyno yet.
Old Oct 20, 2003 | 07:08 AM
ZEROLIFT's Avatar
ZEROLIFT
i made a mistake...
i meant
251@the wheels....
Old Oct 20, 2003 | 07:19 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
LOL - 251 makes more sense.
Old Nov 5, 2003 | 01:49 AM
ether's Avatar
ether
Originally posted by Z1 Performance
Honestly, I don't think even the fan will help on the dyno, but the shop we use has a HUGE one.
Hopefully will get over there this weekend for a test.
Next up will be the ground wires and crank pulley - gets a bit expensive at $100 a pop to go for each individual mod
What do you all suggest for the dyno? Should be do the intake as a standalone mod, or consolidate it with either the pulley and/or ground wires. If done as astandalone, we would probably then do the pulley and ground wires together as one dynoed mod
Let us know before I book the appt
thanks
any chance you have the done the dyno. looking to see before and after hp gains for just the intake.. thanks
Old Nov 5, 2003 | 07:03 AM
Jun's Avatar
Jun
i was wondering where you bought and how much you paid. That is one sweet-looking intake.
Old Nov 5, 2003 | 07:10 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
We decided not to bother just dynoing the intake due to time constraints. Doing it after every mod just take too long. Since this time, I have added a brand new Apex'i exhaust (not the N1, its one of the newer J spec ones), and will likely install the crank pulley as well, then redyno (of course at teh same palce we always use).
Old Nov 5, 2003 | 08:06 AM
Chebosto's Avatar
Chebosto
any way you can measure the amount of pressure inside that carbon bulb? it would be really interesting to compare that with the stock air box's pressure while driving..
i think Crawford did a test with the stock air box and found that highway speed driving actually pressurized the stock air box to like 0.2psi or something.. i forget what he told me...
does the Gruppe M have a velocity stack?
Old Nov 5, 2003 | 09:11 AM
Ultimateone's Avatar
Ultimateone
Best bet is www.renn-sport.net and ask for Samir or Sam
Old Nov 6, 2003 | 01:03 PM
Z1 Performance
Former Sponsor
Cheston - I for one am not drillinginto it to find how much pressure it runs I really could care less to be honest - it madea difference up top, over 4500 rpm, where the car needs it most IMHO. Also, do you think that the .2 psi is there before it enters the TB? I (personally) doubt it.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
