Suggestions for Crawford Plenum Installation?
Old Oct 15, 2003 | 03:56 PM
Ricky's Avatar
Ricky
Default Suggestions for Crawford Plenum Installation?
Anyone have any suggestions? Thanks
Old Oct 15, 2003 | 04:05 PM
PhoenixINX's Avatar
PhoenixINX
Default Re: Suggestions for Crawford Plenum Installation?
www.crawfordzcar.com
All the install data under the support section!
Old Oct 15, 2003 | 05:14 PM
MY350Z.COM's Avatar
Ricky, there really isn't much to it. Simplest mod I've done. Easy bolt in and out.
Have fun!
Victor
Old Oct 15, 2003 | 11:23 PM
fdao's Avatar
fdao
Just read the installation manual carefully. When you reach the end of the manual, read it again, but this time from back to front. This way, you'll account for all the bolts and vacuum hose that may be left out .
Old Oct 16, 2003 | 04:50 AM
Ricky's Avatar
Ricky
I heard not to tighten the bolts too tight since the ones given break easy? And if they break I'll have a vacuum leak?
Should I buy new bolts, or use ones provides?
When disconnecting the strut bar, is there any precautions with that also? Thanks!
Old Oct 16, 2003 | 05:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Just take your time with everything and you will be fine. You sound kind of timid about doing this just have a friend that is handy help you out. Let us know how it goes, I'd like to see your car dyno with the plenum....
Old Oct 16, 2003 | 02:21 PM
Ricky's Avatar
Ricky
Not timid, I did the exhaust intake and test pipes with a friend helping out, I just want to make sure if any suggestions before I do it so I do it once, and right.
Someone gave me a good suggestion on exhaust, use new gaskets.. so just checking if there's any suggestions
Old Oct 16, 2003 | 02:23 PM
Ricky's Avatar
Ricky
If you ran a 13.7 stock, I'm sure with my car you should break 13.5's easy Might have to meet and let you try it.. my launching isn't as good as I'd like it to be yet.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
