Smog Check Question?
Old Jan 20, 2010 | 01:51 PM
Panu's Avatar
Panu
Default Smog Check Question?
Will I pass smog check with HKS Dual Hi-Power Ti Exhaust? Anyone has experienced? Thnx ahead
Old Jan 20, 2010 | 02:20 PM
TheFarmer's Avatar
TheFarmer
Is that the only mod you have?
Old Jan 20, 2010 | 02:22 PM
scotts300's Avatar
scotts300
Where do you live? Smog regs are very different across the nation.
Old Jan 20, 2010 | 02:26 PM
zrzly?'s Avatar
zrzly?
most OBDII tests (which is what your vehicle should require) do a scan through the DLC for any systems not complete, DTC's or the presence of a MIL (or CEL). OBDII tests fail for any number of reasons, not complete systems coming from resetting a battery and not allowing enough time for the system reset, and with DTC's you can have one of those for any number of reasons. and hopefully a CEL would be obvious. assuming the HKS is your only mod, or at least as long as you have no CEL because of DTC'S you should pass any OBDII test.
Old Jan 20, 2010 | 02:58 PM
Panu's Avatar
Panu
Yes, and i'm in LA county.
Old Jan 20, 2010 | 06:42 PM
terrasmak's Avatar
Considering a cat back exhaust is completely legal, YES.
Old Jan 21, 2010 | 10:13 AM
Dr. Venture's Avatar
Dr. Venture
<~~does own inspection!! YAY!!!!
ZrZly hit it right on the head. Less they do idle tests down by you for an obvious modification reason your safe.
Old Jan 21, 2010 | 11:45 AM
s31t8n8's Avatar
s31t8n8
you do your own inspection??
Old Jan 21, 2010 | 03:00 PM
zrzly?'s Avatar
zrzly?
I do my own inspections as well lol. texas isn't hella strict tho, and depending on the county, you only have to pass a safety inspection
issyz
Jul 2, 2017 03:04 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Tochigi_236
Sep 27, 2015 03:40 PM
