light weight exhaust survey
Old Oct 26, 2003 | 08:37 AM
boyze's Avatar
boyze
Question light weight exhaust survey
I'm curious what the interest level would be for an aftermarket low weight exhaust system that has the same function as the better replacement systems for reduced back pressure, enhanced low frequency sound and longevity. We're developing a new technology that should enable us to reduce the weight of traditional exhaust systems by 50 to 75%.
Thanks in advance for your input.
Old Oct 26, 2003 | 08:55 AM
Moroccan_Mole's Avatar
Moroccan_Mole
sound i think would be an important factor ... i want something that sounds like stock.
depending on cost/weight/sound/appearance ... i would be very interested
right now im looking at the vielside tear drop exhaust ... but its very very expensive
Old Oct 26, 2003 | 08:59 AM
little_rod's Avatar
little_rod
Well, a power increase would definitely help the cause.
Old Oct 26, 2003 | 09:01 AM
MY350Z.COM's Avatar
Default Re: light weight exhaust survey
If you can keep the price down then it would be a nice option.
Old Jan 11, 2004 | 09:35 AM
toykilla's Avatar
toykilla
umm? titanium exhaust is already available and saves alot of weight
Old Jan 11, 2004 | 11:07 AM
boyze's Avatar
boyze
True. Ti should be roughly half the weight of a steel system from the cats back assuming a simple material change. But I'm working on an idea that should be significantly less weight but hopefully comparable cost and sound quality. Trying to get some samples made and installed on my Z to test in the next few weeks.
more later
Old Jan 11, 2004 | 11:57 AM
little_rod's Avatar
little_rod
Well, dude, there is not an exhaust on the market that is Ti and can support a turbo. Sure you can custom something, but there is not a kit out there. Might be a market worth looking into, being able to support a turbo setup with a dual look having the diameters you need for a turbo.
Old Jan 11, 2004 | 03:11 PM
mybabyblueZ's Avatar
mybabyblueZ
Borla DUal catback is 12 lbs lighter than the OEM exhaust and sounds insane....also can be found for 699 online and installation can be done in a few hours by yourself, nuts and bolts only no welding....
Old Jan 11, 2004 | 03:42 PM
Drag Limited's Avatar
Drag Limited
Full Iridium Exhaust? sry thats just for ***** and giggles
Old Jan 11, 2004 | 04:52 PM
Enron Exec's Avatar
Enron Exec
Old Jan 11, 2004 | 06:43 PM
navybulldog68's Avatar
navybulldog68
Toykilla, you are one hot mama.
Old Jan 12, 2004 | 04:42 AM
boyze's Avatar
boyze
Not sure why the Ti folks haven't offered larger diameters. Probably see it as a fringe market and they would have to tool up for the larger diameters and attaching hardware. Ti can also be expensive as raw material.
Our concept will work in any diameter.
Old Jan 12, 2004 | 05:57 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Better performance at a good price is always a good bet.
Old Jan 12, 2004 | 06:29 AM
toykilla's Avatar
toykilla
im so embarassed
Old Jan 12, 2004 | 07:47 AM
paisturbo's Avatar
paisturbo
I believe the Injen exhaust is 1/2 the weight of the stock one from what i understand and it is true duals.
Old Sep 1, 2004 | 10:13 AM
toykilla's Avatar
toykilla
any updates
Old Sep 1, 2004 | 11:39 AM
kzshin's Avatar
kzshin
I thought Greddy is coming out Full Titanium Exhaust with 80mm single pipe, single outlet.
I would think Greddy Racing can support turbo, since they develop and sell turbo kit.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
samansharif
Sep 25, 2015 12:31 PM
