Nismo S-tune Exhaust Midpipe
So last week I had my car up on a lift and found that my Nismo S-tune Exhaust has a crack around the Midpipe flange. You know the flange that meets the Y-pipe. I have never heard of a Nismo Exhaust cracking around the Midpipe flange. Everyone I have seen has been cracked at the Y-pipe flange.
Never the less I got it off and removed the supports that are welded to the flange. I will be heading to the welder in the morning.
Pic's.
Pic's.
Good spotting! What made you check though?
I've noticed that one of the hangers that are welded to the exhaust has broken its weld from the exhaust. On idle sometimes, you can here it rattle.
There must be quite a bit on movement in our exhausts.
I am also going to be replacing my Berk HFC with the New Berk HFC with the revised double gusset support brackets. I currently have the real old style with the single gusset support bracket. These where know for cracking. The folks at Berk took care of me and cut me a Great deal on new ones with the revised support brackets.
i have the revised one's and my driver side cracked right at the support bracket. If the support bracket was not there i'm sure they would still be good. that's probably why this time i'm gonna go with fast intentions since they don't use support brackets and i haven't read any complaints with them.
That's not a huge scrap from bottom out. That's where I grinded off the one of the two support gussets that where welded to the flange so the welder could weld around the whole flange.
