XERD headers+Borla TD+AEM CAI+Crawford plenum dynoed!
Old Nov 12, 2003 | 05:31 PM
Z PHAT Z's Avatar
Z PHAT Z
Default XERD headers+Borla TD+AEM CAI+Crawford plenum dynoed!
I'm don't know what to say. Today I went to dyno my car with the plenum installed. Well, I didn't gain any power. Based on my based runs couple weeks ago, I gained maybe 1 WHP. I don't know what's wrong, but I will un-install the plenum and make sure everything is secured and no leak then bring back to the dyno shop to do couple more runs.
Patrick
Old Nov 12, 2003 | 05:32 PM
MY350Z.COM's Avatar
something is definitely wrong here. sorry to hear that man.
Old Nov 12, 2003 | 05:36 PM
jeffw's Avatar
jeffw
Is the plenum the only thing added since your last dyno or are you comparing your stock-only base dyno to all those extra mods?
Jeff
Old Nov 12, 2003 | 05:42 PM
Ultimateone's Avatar
Ultimateone
Im sure hes talking about just adding the plenum.
Old Nov 12, 2003 | 05:44 PM
Z PHAT Z's Avatar
Z PHAT Z
Just added the plenum to the setup. Hopefully after checking everything and re-dyno, the number will be different. If not then I will sell the plenum .
Old Nov 12, 2003 | 06:15 PM
spazpilot's Avatar
spazpilot
Default Re: XERD headers+Borla TD+AEM CAI+Crawford plenum dynoed!
Patrick
do a dyno with an a/f monitor. I bet you are running so lean you are losing power. That is what is happening with jason at performance nissan!
Old Nov 12, 2003 | 10:00 PM
rodH's Avatar
rodH
Default Re: Re: XERD headers+Borla TD+AEM CAI+Crawford plenum dynoed!
is there certain mods that (he has listed) that tend to make a car run lean????
Old Nov 12, 2003 | 10:13 PM
ajk4's Avatar
ajk4
i second what spazpilot said, use a wideband sensor to check your air/fuel ratio. if they did this when you dynoed please post your dyno sheet, and if you didnt i would definetly go back and pay the extra $20 for it cause it could save your engine. the only mod that could possibly make it run lean is the plenum. it might be the combination of the cai and the plenum, but still that would be a stretch. plus, alot of people on this board are running with a cai and crawford plenum, seemingly without problems (although i havent seen an a/f #'s for this specific setup).
Old Nov 12, 2003 | 10:36 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
This situation sounds familar.
Old Nov 13, 2003 | 04:21 AM
VandyZ's Avatar
VandyZ
With those other mods, I can see a low PEAK hp change being possible. You have done a good job of making a "more" free flow setup. Check your hp at higher rpms. If it is not significantly higher, then you have a problem. Our observed HP gains all happened between 12.8 and 13.5 on the A/F meter, so use that as a basis on your next run. Also if you want to make things more interesting disconnect the AEM for a pull. Not saying that it is a problem as you have dynoed with it before, but Paulo here gained 9-11 HP when he took it off (when base lining before the procharger went on).
Old Nov 13, 2003 | 04:32 AM
FairladyZ's Avatar
FairladyZ
Has anyone ever flow benched are plenums? And then flow benched the new plenum? How do you know the stock one doesnt flow good?
What is done to the plenum to make it better?
Old Nov 13, 2003 | 05:23 AM
VandyZ's Avatar
VandyZ
Yes, search the past posts. To sum it up, it had a 30% loss to the front cylinders. With the new redesigned plenum it went down to a little under 5% loss.
Old Nov 13, 2003 | 04:37 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Post up the dyno sheet
Old Nov 13, 2003 | 06:45 PM
dwnshift's Avatar
dwnshift
Do you have a TS ECU reflash?
Old Nov 13, 2003 | 08:46 PM
Z PHAT Z's Avatar
Z PHAT Z
I don't have the TS ECU. Here are 3 runs that I did. Lost 3 MAX TQ.
run2
run3
run4
Old Nov 14, 2003 | 04:06 AM
Mikestro's Avatar
Mikestro
how can I convert the chart into a readable format? My html editor doesn't seem to be doing the trick.
Old Nov 14, 2003 | 08:23 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
how much whp and torque do you have from the dyno? can't see the dyno sheet.
Old Nov 14, 2003 | 09:17 AM
Z PHAT Z's Avatar
Z PHAT Z
go to www.dynojet.com and download the viewer.
Old Nov 14, 2003 | 10:02 AM
dwnshift's Avatar
dwnshift
I stongly suggest the TS ECU with your current modifications. We have tested many differnt "maps" and one way either side makes a big difference.
The MAF is also another area to look at to make sure there isnt anything wrong.
Also resetting the system by putting it in diagnostic made and idle learing is also a good thing to do after those type modifications.
Old Nov 18, 2003 | 04:08 AM
teh215's Avatar
teh215
Can putting it in diagnostic made and idle learning be done without a Consult unit?
allmycarsdie
May 13, 2016 04:38 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
