Order of Torquing Down Exhaust Bolts
Old Dec 11, 2010 | 08:12 AM
Shawz1102's Avatar
Shawz1102
Default Order of Torquing Down Exhaust Bolts
Hi guys, as you may know from my other thread called "exhaust rattle", my midpipe rattles because it's hitting the M brace. I tried torquing it down evenly on each flange and pushing up the Y pipe while torquing it down.
I'd like to know what the correct order for torquing down the catback exhaust bolts is so that the flanges and pipes and evenly torqued/balanced.
I have a Nismo S tune Y pipe back exhaust with Motordyne ART pipes and XYZ pipes.
Old Dec 11, 2010 | 08:28 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
shouldn't matter the order, as long as its done opposite side to opposite side
Old Dec 11, 2010 | 08:38 AM
Boba's Avatar
Boba
then it must be that i'm not pushing the y pipe up enough... do you have any suggestions on what i can put underneath the y pipe to keep it pushed up? it's hard to keep it up with my legs and torque at the same time... i do it on jackstands.
Old Dec 11, 2010 | 08:57 AM
Z1 Performance
Former Sponsor
you shouldnt need to be pushing anything up or down
you could use another jack, or another jackstand
Old Dec 11, 2010 | 11:15 AM
User 42426's Avatar
User 42426
shouldnt matter which bolts you torque first. However, dont tighten them all the way until you have all the bolts semi tightened. Then go back and re-tighten all of them. When I was installing my y pipe, I accidentally flipped it around, and it didnt fit all that well, then flipped it over and it fit perfectly, so maybe your not bolting it the right way. Also, I used another jackstand to prop the y pipe up so its level with the other components. Either that, or just use a box or something, not that hard to find something to hold it up, or a friend :]
Old Dec 11, 2010 | 11:54 AM
Zlucky1's Avatar
Zlucky1
Originally Posted by stevehl
shouldnt matter which bolts you torque first. However, dont tighten them all the way until you have all the bolts semi tightened. Then go back and re-tighten all of them. :]
+1!
Old Dec 11, 2010 | 12:31 PM
Have you tried a wooden shim?
Put the shim in place.
Tighten the bolts.
Remove shim.
Old Dec 11, 2010 | 12:49 PM
Shawz1102's Avatar
Shawz1102
Tighten the bolts.
Remove shim.
will try it, that's easier than jackstands! thanks davidv
Old Dec 12, 2010 | 10:37 AM
tylerxfire's Avatar
tylerxfire
front to back
350z82
Oct 1, 2015 06:25 PM
