Hav you used aftermarket MAF sensor??
Old Mar 18, 2011 | 08:55 PM
cleanddong's Avatar
cleanddong
Default Hav you used aftermarket MAF sensor??
Hello,
Iam about to buy new MAF sensor..
hav you guys used aftermarket MAF sensor?
I looked websites, and found out three of them
1. Hitachi Mass Air Flow Sensor
2. A1 Cardone
3. Jet Performance Mass Air Flow Sensor
If anyone had these, plz tell me the experience.
thanks
Old Mar 19, 2011 | 06:43 AM
glenns280's Avatar
glenns280
I have the first one..I think its the same brand as oem.I have had mine for 3 yrs
Old Mar 19, 2011 | 07:32 AM
cleanddong's Avatar
cleanddong
Thanks for coment, any issue with them.?
After u installed it, did u need to reset ur ECU?
Thanks
Old Mar 19, 2011 | 12:03 PM
djamps's Avatar
djamps
If you go with anything other than stock you will mess up your tune badly. There's no reason to use another MAF sensor unless you're maxing out the stock MAF which is good for 400+HP.
Old Mar 20, 2011 | 04:50 AM
cleanddong's Avatar
cleanddong
Yeah, thats true too.
But the cost is different between OEM and aftermarket.
Old Mar 20, 2011 | 07:02 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I believe the OP is looking at OEM units, but produced by outside manufacturers. One of them is bound to be the OEM for Nissan (Nissan isn't in the MAF manufacturing business, they source it from an outside supplier)
OP - where are you located? What's the exact year, and build date of your car? How do you know your existing MAF needs replacement in the first place?
Old Mar 20, 2011 | 07:59 AM
cleanddong's Avatar
cleanddong
I'm in michigan, and shop found out that need to be replace maf sensor.
It's 2003 350z. I'm now thinking to getting HItachi Maf sensor
Old Mar 20, 2011 | 03:55 PM
cleanddong's Avatar
cleanddong
have you guys used UpRev's upgraded HPX MAF sensor ??
Old Mar 21, 2011 | 09:22 AM
Z1 Performance
Former Sponsor
unless your car has MAJOR engine upgrades, it would do you no good
what is the car doing that leads you/your shop to the conclusion that the MAF is faulty?
Old Mar 21, 2011 | 11:48 AM
cleanddong's Avatar
cleanddong
lack of power when I put gas on after 4000 RPM.
Old Mar 28, 2011 | 05:52 AM
cleanddong's Avatar
cleanddong
after you replaced your maf sensor, do you have to reset ecu?
or anything?
Old Aug 30, 2012 | 12:16 PM
Knuckles256's Avatar
Knuckles256
aftermarkets are just fine.
Old Jun 4, 2013 | 06:32 PM
Olsi's Avatar
Olsi
I'm having trouble with my 350Z. I was wondering if someone could steer me in the right direction
I used engine Gunk cleaner to wash the bay and I sprayed off the engine when I started it up it wouldn't rev pasted 2500 then the Check Engine light came on along with VCD and Slip light.
I checked the code and P0102 came on. Mass or volume air flow a circuit low input .
I tried everything. With a scanner I can see that the sensor is some how working Bc it's reading flow.. I haven't changed any fuses Bc I dont know where to look. I would appreciate your help.
Old Jun 4, 2013 | 08:06 PM
bealljk's Avatar
bealljk
Well, you got alot of searching to do then…keep looking on the forum for similar issues and similar 'check-engine-light' codes…
As far as your wash goes - take 20 or 30 minutes and make sure all your wire harnesses are connected and nothing came loose.
You have two fuse boxes - below and to the left of the steering wheel and one right behind the battery - search for how to access each…pretty simple.
Old Feb 29, 2020 | 05:24 PM
Patrick Nious's Avatar
Patrick Nious
Default Jet MAF
Hello,
2. A1 Cardone
thanks
I have used the Jet MAF ON 4 of my cars now. 06 Maxima, 05 g35 , 09 maxima. I just got another one today for my 06 350z. I have a cold air intake on all cars listed. Under Hard acceleration it’s seem to hit a flat spot in the mid range and then resumed to accelerant. After replacing the MAF with the Jet MAF that problem was taken care of and now pulls throughout the power band.
liqalu04
Jan 2, 2022 12:58 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
