Fujitsubo Legalis R
Old Mar 1, 2012 | 06:46 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I used to have the Titanium version, which is one of the rarest exhausts around. Literally the best sounding exhaust I've heard, and I've been around for quite a long time. I miss it everyday.
Old Mar 1, 2012 | 06:59 PM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Fujitsubo is one of my favorite exhaust despite no Y pipe included with the purchase.
Look stock and the sound isn't too loud. From inside it sounds good at WOT, just perfect imo.
Old Mar 3, 2012 | 09:34 PM
8 post in 3 years and I was stupid enough to expect a reply. Lesson learned.
Old Mar 3, 2012 | 09:54 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
From what i'm reading, this exhaust is quieter than stock.
Old Mar 4, 2012 | 08:00 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
It isn't.
Old Mar 5, 2012 | 04:45 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
I've not seen anything stating otherwise
Old Mar 5, 2012 | 05:11 PM
0jiggy0's Avatar
0jiggy0
I've heard the ti version. Such a clean and exotic sound. I really want one but with these being blown out for so cheap I may just grab the ss version.
Old Mar 5, 2012 | 07:49 PM
Flo-ridaZ33
I've had one... now I have:
Greddy Spectrum Elite
XYZ Resonated Y-pipe
ART Pipes
No rasp and pretty docile until you gun it... then the heavens open and babies are born.
Fuji Set up: Disclaimer... new neighborhood and no one lived there at the time.
http://youtu.be/T8aPg1u-7yY
http://youtu.be/Sv73x0f4XOY
Old Mar 5, 2012 | 08:06 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
So was that Fuji setup with the ART and XYZ (straight pipe i assume?)
Any other vids of it?
Old Mar 5, 2012 | 08:12 PM
3hree5ive0ero
Retired Admin
Yeah, the tone is definitely a clean and crisp one. The one that I had was a first edition (has the 3 dots on either side of the Z on the muffler, whereas the later versions had a rolled tip and no etching on the muffler), too.
For the price of the SS nowadays, it's definitely a smarter choice financially to go with the SS.
Old Mar 5, 2012 | 08:21 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Hmm, i know listening to some stock 350 vids that they have a good tone, it's just quiet.
You seem to have a nice sound recording ability there, i don't suppose you have any before vids?
I'm just wondering how much more it sounds like that without the ART and XYZ?
Old Mar 5, 2012 | 08:26 PM
Flo-ridaZ33
That's just the Fuji set up to include the Y-pipe. I never ran the Fuji with the ART pipes... it sounds nice, no drone but it does rasp sometimes. My new set up has NO rasp and just sounds retarded awesome at full throttle.
Old Mar 6, 2012 | 01:00 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
You still running an OEM mid-pipe Flo?
Old Mar 6, 2012 | 02:42 AM
Flo-ridaZ33
For the time being yes.
Old Mar 6, 2012 | 09:45 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
So, the video shows all stock except for Fujitsubo Y pipe, mid pipe and rear muffler?
Why are you running oem mid pipe now with the ART and new muffler?
I'm trying to get an idea of the volume, if you were running all stock, so cats, and just the Fuji back, then that's not bad, ARTs, high flow cat on an XYZ and the fuji mid and muffler would sound louder i assume.
Old Mar 6, 2012 | 10:23 AM
Flo-ridaZ33
Ok to be clear... The Fuji set up did NOT have the XYZ or Art pipes, the Fuji set up was only the Fuji Y-Pipe and cat back exhaust. The vid I posted are ONLY the Fuji set up.
The Greddy is an axle back exhaust so it's just the muffler... I have a Nismo Mid-pipe in my storage that I'm thinking I might put on. Your assumption is correct... The volume will go up with the ART pipes and the XYZ Y-pipe, keep in mind I picked up resonator instead of a cat or straight pipe so my build was a comprise(obviously the cat will be quieter... MD uses a V-Band attachment so they are interchangeable) and not a ***** out racecar. I have a dyno vid and there's absolutely no rasp at WOT or anywhere in between.
Old Mar 6, 2012 | 10:55 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Great, thanks.
Any vid of the Greddy?
I'm also assuming the Fuji mid pipe wouldn't connect to the greddy muffler? hence the stock mid pipe being used?
Also, FYI, the HFC doesn't cut out as much sound as the resonator for the XYZ pipe attachments. But the resonator can help cut out any remaining rasp that might/may be present.
I really want the MD y-back, but seriously can't afford it, i technically can't afford the Fuji either, but if they accept a low offer, i might, so long as it's worth it. Worth it will be better breathing and an increased exhaust note/volume.
Old Mar 6, 2012 | 11:27 AM
  #38
F2CMaDMaXX's Avatar
F2CMaDMaXX
I used to have a *full* Fujitsubo system on my Prelude, and i keep forgetting that if you "hack the gibson" on their Japanese site, they have some more interesting details on the exhausts.
So, for the Legalis R on the 350Z:
Spec
----------------------------Standard (STD)----------------FUJITSUBO
Intermediate acceleration
(30km / h → 110km / h
 speed 3)---------------------2.8 seconds--------------2.6 seconds
Maximum output-------174.7kw (237.6ps) / 6240rpm-------179.8kw (244.5ps) / 6150rpm
Maximum torque------301.8N-M (30.8Kg-M) / 4770Rpm----311.6N-M (31.8Kg-M) / 4700Rpm
Weight muffler-------------------20.4kg-----------------------17.5kg
※ value-house testing. Measurement data is different from the vehicle, such as the measurement conditions.
--------------------------------Standard (STD) FUJITSUBO
Volume idling------------------------60dB-------------------------71dB
Proximity exhaust noise (4650rpm)----82dB--------------------------88dB
3000rpm----------------------------72dB--------------------------77dB
5000rpm----------------------------84dB-------------------------87dB
4000rpm ~ 6000rpm response--------99dB-------------------------108dB
Last edited by F2CMaDMaXX; Mar 6, 2012 at 11:34 AM. Reason: Formatting nightmare!!
Old Mar 7, 2012 | 07:55 AM
  #39
Nismo1534's Avatar
Nismo1534
I had this exhaust on my Nismo with Motordyne's resonated Y-Pipe and ART pipes. With that combo, it was definitely quieter than stock. I removed the resonator from the y-pipe and used a straight pipe, which made it sound about as loud as stock, but there was noticable rasp. Paid $1,100 for the Fuji, without the Y-Pipe.
Please see my thread for pics/vids of this exhaust
EDIT: Also, note that the Fujitsubo Legalis-R came in two models, one for the 03-06 and one for the 07-08. They both fit all years, but the 07-08 is said to be louder. I had the 07-08 model and it was still very quiet.
Old Mar 7, 2012 | 08:11 AM
  #40
F2CMaDMaXX's Avatar
F2CMaDMaXX
I think the stats i found/posted are for the 07 version.
Interesting you had the exhaust only as loud as stock with the straight pipe, i was going to run this with the HFC (which would be louder than the resonator) but hoping more than stock at least.
I saw your oregon plate, where abouts are you? Doesn't sound like this is a good exhaust for me as i want it a bit louder than stock.
