how to remove intake
Old Feb 7, 2012 | 08:33 PM
lancer1088's Avatar
lancer1088
Default how to remove intake
hi im a new owner of a 2003 nissan 350z touring i want to clean my maf sensor i remove the bolts holding the intake box but it wont come out it wobbles and im pulling and it wont come out PLEASE HELP! is there another bolt im missing besides the one on the top right of the box thank u
Old Feb 7, 2012 | 09:23 PM
R350Zz33's Avatar
R350Zz33
go to the gym and try again or let a 12 year old boy show u how
Old Feb 7, 2012 | 09:34 PM
The sensor is connected to the intake tube with 2 screws. Thats it.
Old Feb 7, 2012 | 09:41 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Surprising...
Old Feb 7, 2012 | 09:51 PM
NateZ08's Avatar
NateZ08
im going to give you some advice, especially since you have 2 posts. research about 5 times before asking on a forum. you will get flamed if the questions are like this. the community is a very helpful bunch but only for those who aren't lazy.
Old Feb 7, 2012 | 10:29 PM
R350Zz33's Avatar
R350Zz33
why the **** are you helping him. lol jk
Old Feb 7, 2012 | 11:26 PM
350zky's Avatar
350zky
make sure not to move the valve around, it will make your car trip out. if this does happen and you notice a high rpm idle then you would need to recalibrate the throttle body, just disconnect your battery and reconnect it should go back to normal
Old Feb 7, 2012 | 11:28 PM
Cody750's Avatar
Cody750
because race car!
Old Feb 8, 2012 | 02:59 AM
DavesZ#3's Avatar
DavesZ#3
1) no need to remove air box. if you insist, there's a pin on the bottom of the airbox that is plugged into a rubber grommet on the frame supporting it. That's what is stuck. Pull up.
2) disconnect battery.
3) remove MAF sensor and leave airbox alone. Spray carefully, let dry, make sure you reinstall in proper direction.
Old Feb 8, 2012 | 05:38 AM
PerfZ's Avatar
PerfZ
Good advice but it doesn't apply to cleaning the MAF sensor - as already pointed out you simply unplug/unscrew the sensor. And it is probably best to never move the valve in the TB by hand - that reset is a PITA and often doesn't work without a trip to the dealer.
Old Feb 8, 2012 | 11:11 AM
lancer1088's Avatar
lancer1088
thanks alot to people that actually wants to help in this forum and for those who has no life posting b.s here grow up **** loser.
Old Feb 8, 2012 | 05:53 PM
TurboBob's Avatar
TurboBob
I suggest you follow the link below and download the appropriate service manual for your 2003 Z. Read the section that applies to what you want to do. Then if you have questions more people will be willing to help.
http://www.nicoclub.com/FSM/350Z/
This link is also located on this forum if you had searched for it.
apex locator
Jul 23, 2021 02:27 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
