loss of power after mods
Old Mar 24, 2012 | 01:14 PM
supraturboman's Avatar
supraturboman
Default loss of power after mods
Ok so I recently installed a set of stillen test pipes Godspeed exhaust nismo intake and a kinetix v+ Plenum. The problem I am having is now my car is slower. It doesn't our you back in the seat anymore. The car is a 03 enthusiast with only 26k on it. I am getting a Cobb AP on Monday so hopefully that will help. But anything I'm missing?
Old Mar 24, 2012 | 01:18 PM
kacz07's Avatar
kacz07
You're prob running really lean and it's pulling timing. A tune will help.
Old Mar 24, 2012 | 01:20 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
correct a tune will fix your issue unless its exhaust, vacuum leaks etc. Also dump the cobb and go uprev
Old Mar 24, 2012 | 01:23 PM
supraturboman
There are no vacuum leaks. I did check that. And why do you say dump the Cobb?
Old Mar 24, 2012 | 01:24 PM
2004Black350z
Exhaust Whore
bc its Chit unless you have a tuner thats AMAZING with Cobb. Why buy a tuning program thats discontinued? That should have been an obvious pass
Old Mar 24, 2012 | 01:29 PM
supraturboman
Ok with that being said now, what do you think of the pre made maps that they offer?
Old Mar 24, 2012 | 01:32 PM
2004Black350z
Exhaust Whore
that no one should used pre loaded maps since everything down to local weather have a factor on tuning. With that being said I would only use it to drive to the tuner and have tuned
Old Mar 24, 2012 | 01:35 PM
supraturboman
You can still get maps from their website? They must still offer technical support. I should have done more research before buying it. But what's done is done. And I do know a great tunner for Cobb.
Old Mar 24, 2012 | 01:39 PM
2004Black350z
Exhaust Whore
then you're ok.
Old Mar 24, 2012 | 01:45 PM
Duckeee's Avatar
Duckeee
youll get most power with a custom tune from Uprev. dont waste your money on the Cobb especially after they stopped R&D on it a few years ago.
but yes, your problem is that you need a tune. with that many bolt ons youre probably running really lean
Old Mar 24, 2012 | 02:58 PM
supraturboman
Ok. Well I will plan to get it dyno tuned asap. It just really had me freaked out at first.
Old Mar 24, 2012 | 03:26 PM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
you'll want to have someone make up a custom map for you on COBB, I wouldn't really go for a retune unless it was custom (not because it's unsafe, just because I don't think it'd be worth the money). I use the COBB on my HR, but it was a custom tune by my neighbor who used to e-tune for COBB. I suggest just making sure a nearby shop has a capable cobb tuner (an individual/person, not the unit). The retune really opened my car up. You'll also need a retune to deal with resetting your MAF. Air intakes mess them up, and COBB specifically says to use the stock airbox with their factory maps.
Old Mar 24, 2012 | 03:58 PM
R350Zz33's Avatar
R350Zz33
they no longer support the 350z so why should we support them
Old Mar 24, 2012 | 04:30 PM
JCITY's Avatar
JCITY
Don't waste your time with the Cobb.It will be hit or miss.
Get a proper dyno tune.
Old Mar 24, 2012 | 04:35 PM
supraturboman
Well unfortunetly I already have the Cobb unit so I am kinda stuck with it. Cobb can't be that bad. I mean if the person that is tunning it is good, the tune should be good.
Old Mar 24, 2012 | 05:03 PM
Surg's Avatar
Surg
It could be the intake.
Old Mar 24, 2012 | 05:51 PM
supraturboman
When I installed everything, I did one mod at a time then drove it. I did this just to make sure everything was fine. But I noticed the start of the issue when I put the test pipes on. Then it got even worse with the exhaust and now finally the worst when the V+ was put on. All the mods were done the same day, just one at a time.
Old Mar 24, 2012 | 06:16 PM
And you know this how? Before and after dyno? Or are you just taking a stab in the dark?
Old Mar 24, 2012 | 06:36 PM
supraturboman
The good old butt dyno is telling me so. It doesn't pull as hard. Its extremely noticeable. Its not running rough. Just feels sluggish
Old Mar 24, 2012 | 06:55 PM
Subject is as old as jesus. Any simple bolt-on mod to a Z will alter both torque and horsepower curves. Sometimes good -sometimes bad.
