confused about the fujitsu y pipe
Old Dec 31, 2003 | 11:42 AM
Rice_Boii's Avatar
Rice_Boii
Unhappy confused about the fujitsu y pipe
I was reading that the fujitsu y pipe is nothing special. Im a noob at this. I want to do the fujitsubo exhuast along with y pipe but am i spending my money correctly? Is the y pipe upgrade good? Will i benifit anything out of it? Should i just get the exhaust and not the y pipe? I need all the info i can get into my head about this y pipe. Thanks
Old Dec 31, 2003 | 12:34 PM
AboostedG's Avatar
AboostedG
Twin Spoolin
I've been doing research as well and yes it would be a good thing to do a Y-Pipe. I talked to this one guy and he went with the Japtrix Y-Pipe and gained 5 HP with his Fujitsubo Exhaust. I had asked him why he didn't get the Fujitsubo Y-Pipe and the Japtrix Y-Pipe was the best for the price and gains. He now has about 12 HP for his Exhaust which is about the same as the Dual Stillen claims.
Plus after that, put on some Random Tech Cats as well.
Old Dec 31, 2003 | 04:58 PM
fdao's Avatar
fdao
Default Re: confused about the fujitsu y pipe
Well, if you get the Fujitsubo Y-Pipe and Muffler, it'll cost you more than if you get the NISMO Exhaust, which has the same features.
If I were you, I would swap the Y-Pipe and the straight pipe with resonator, following it. I would keep the stock muffler as it's quite unrestricted, from what I've gathered. If sound is important to you, than just get the NISMO or Borla. Next to the CATS, the Y-pipe/straight pipe w/resonator are probably the next restricted components.
Old Dec 31, 2003 | 05:06 PM
FairladyZ's Avatar
FairladyZ
I would go with the japtrix because its cheaper.
Old Dec 31, 2003 | 05:46 PM
westpak's Avatar
westpak
SFZCC
That is probably me, if you go for a non-dual system then you should get a y-pipe to ge the most out of the system.
The Japtrix one I think is the best deal, I haven't researched lately. The Dyno'd the car with just the mid-pipe they manufactured and got 6HP then they dyno'd again with y-pipe and mid-pipe and got 11HP, therefore they attributed 5HP to the y-pipe.
As Frank says the muffler doesn't seem to make a difference, Japtrix tried different ones and other than changing the sound it had no impact on the HP.
I originally posted info on it here https://my350z.com/forum/showthread....threadid=26180
Old Jan 1, 2004 | 01:54 PM
MY350Z.COM's Avatar
moved
Old Jan 1, 2004 | 09:48 PM
BlackNissan350z's Avatar
BlackNissan350z
I currently have stock exhaust manifolds, with the test pipes and the rest of the exhaust is stock, will the fujitsubo y pipe match up with the rest of the exhaust?
Old Jan 1, 2004 | 10:48 PM
fdao's Avatar
fdao
Yes, it should, since it comes right after the CATS/Test Pipes.
Old Jan 2, 2004 | 12:09 AM
BlackNissan350z
so there is no problem bolting the fujitsubo y-pipe to the rear section of the stock exhaust
Old Jan 2, 2004 | 12:25 AM
fdao's Avatar
fdao
No, however, you should also consider changing the midpipe following it as well, since it's smaller than the y-pipe collector. So, in essence, you have opened up your flow, only to be restricted again at the midpipe.
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
