Rough idle after removal of Motordyne spacer
Old Jul 2, 2012 | 08:41 PM
Bmurray350z's Avatar
Bmurray350z
Default Rough idle after removal of Motordyne spacer
So I'm looking to sell my Z soon so I started putting it back to stock today. Took off my Motordyne 5/16 spacer, screwed everything back together, disconnected the battery for 15 minutes, connected it and I have a very rough idle? I figured it's just got to learn the air flow or whatever again. Am I right? I checked numerous times for vacuum leaks or anything and everything is in place.
My car has full bolt ons (minus the motordyne spacer now) and uprev tune.
Old Jul 2, 2012 | 08:59 PM
thisishk350's Avatar
thisishk350
vacuum leak. When in doubt take it all apart and put it back together again, for some strange reason sometimes it works perfectly the second time
Old Jul 2, 2012 | 09:14 PM
Bmurray350z
i've checked for vacuum leaks at least 10 times. everything is snug and in place.
Old Jul 3, 2012 | 05:41 AM
cubs4worldseris's Avatar
cubs4worldseris
you need to do the throttle body position relearn procedure followed by resetting the ecu.
Old Jul 3, 2012 | 05:52 AM
tylerxfire's Avatar
tylerxfire
u shouldnt have to do anything with the throttle reset or idle relearn or anything because you didnt mess with that but its worth a try i guess...id still say theres a vacuum leak somewhere
Old Jul 3, 2012 | 06:15 AM
jdmchino's Avatar
jdmchino
reset the computer
Old Jul 3, 2012 | 06:28 AM
Bmurray350z
it drove normal on the ride home, and idle got a little better. im hoping it will be normal when i go to start my car in a few hours.
Old Jul 3, 2012 | 06:29 AM
huyrua's Avatar
huyrua
MAF sensor put back on backward??
Old Jul 3, 2012 | 06:33 AM
Massios's Avatar
Massios
Make sure your gasket isn't pinched.
Old Jul 3, 2012 | 08:51 AM
bmccann101's Avatar
bmccann101
vacuum leak for sure as others have stated.. take maf cleaner and spray around edges of gasket when cars running.. ANY as in even slight increase in rpm is your vacuum leak .
liqalu04
Jan 2, 2022 12:58 PM
Depravity
Oct 1, 2015 04:49 PM
