PPE Longtube Headers
Old Sep 30, 2012 | 02:41 PM
  #681
terrasmak's Avatar
Originally Posted by 0jiggy0
Its 1 bolt king and its a clamp that comes loose once the bolt is taken out. Might need a lil convincing. Mark the steering shaft and clamp so when you put it back its in the same spot.white out or permanent marker works.
2 bolts on the swivel, one top to the steering shaft, one lower to the rack. The top is keyed and marking is not needed. All you have to do is make the lower.
Old Sep 30, 2012 | 03:20 PM
  #682
juicinjake's Avatar
juicinjake
Originally Posted by kacz07
What?
And still no video?
no not yet. im racing a guy at work with a mildly built big block in an 85 chevy truck. im gonna grab a gopro hero 2 kit before the race. until then it would just be sitting around. i cant imagine what an exciting video me just driving around would make, even on the bottle. i thought id film some action though .... soon enough!
edit: yes and like Vq.turbo.DremZ said, its a g35... hence the lightweight driveshaft mod being on the docket. :/
Old Sep 30, 2012 | 03:22 PM
  #683
juicinjake's Avatar
juicinjake
Mine are on and I got to drive the car. Wow the exhaust note changed, can't wait to get it tuned a bit
haha i know, right? doesnt sound anything at all like before does it? that wide open 4000-7000 is incredible! i try to keep it under 3k when just driving around though.
Old Oct 1, 2012 | 11:03 AM
  #684
terrasmak's Avatar
Anyone else get them installed ?
Old Oct 1, 2012 | 11:15 AM
  #685
KingBaby's Avatar
KingBaby
Hardest Setting
I was able to get the passenger side in and bolt it up....
how many bolts are yall using?
I used six for theone side...
Old Oct 1, 2012 | 11:51 AM
  #686
terrasmak's Avatar
6 per side, same as OEM, then as mentioned i used 2 studs on the top middle cylinder to hold the gasket in place. Once the header was in place i removed the one stud to put a bolt in the hole.
Do not use a stud on the lower middle hole across from the unused upper stud, it will touch the header before it gets tightened down. I made that mistake and had to remove the header to get the stud out once again.
Old Oct 1, 2012 | 12:28 PM
  #687
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Ive been trying to buy some Hardware.
Old Oct 2, 2012 | 01:21 PM
  #688
marsboy999's Avatar
marsboy999
I got my headers also, I have waited a long time to buy a set of longtubes and it was worth the wait. Absolutely beautiful. Unfortunately between ordering these and now, my plans for the car have changed, I no longer have the funds to put the cams in like I was gonna, which is necessary for the non-revups, and so I'm sticking with test pipes and my xyz-pipe that I have. I'm sad to let these go before even getting a chance to hear and feel how they sound. I know this isn't the classifieds, but I'll just say if someone wants a set of these w/o the wait, I got a set sitting close to TO, Canada
Good luck to all the rest who are installing their's, and I along with everyone else am anxiously waiting for videos, but mostly DYNOS!!!!!!!!!!!
Old Oct 5, 2012 | 01:37 PM
  #689
0jiggy0's Avatar
0jiggy0
Ordered my set today, cant wait.
Old Oct 6, 2012 | 12:33 PM
  #690
kacz07's Avatar
kacz07
Dynos already. C'mon.
Old Oct 6, 2012 | 03:30 PM
  #691
KingBaby's Avatar
KingBaby
Hardest Setting
Bitching
*Duke Nukem Voice*
Beautiful noise pending!
Old Oct 6, 2012 | 05:31 PM
  #692
512_Z's Avatar
512_Z
Originally Posted by KingBaby
Bitching
*Duke Nukem Voice*
Hell yeah king!!!
cant wait to hear it
Old Oct 6, 2012 | 07:44 PM
  #693
Frostydc4's Avatar
Frostydc4
Bitching
*Duke Nukem Voice*
Installation completed?
Impressions?
Dont leave us hanging
Old Oct 6, 2012 | 11:04 PM
  #694
KingBaby's Avatar
KingBaby
Hardest Setting
Family and wiring got in the way but I'll fire it up tomorrow!
I jump the gun on that post didn't think soldering would take forever!
NOTE:
When pairing up the wiring.
Black to Black (doesn't matter)
Blue to Blue
White to White
Don't solder on top of the silver wire (stock wire) it will roll off and not stick!
Old Oct 7, 2012 | 08:24 AM
  #695
terrasmak's Avatar
NOTE:
Blue to Blue
White to White
I used sealed but splices on mine
http://www.aircraftspruce.com/catalo...ldersleeve.php they are awesome
Old Oct 7, 2012 | 03:32 PM
  #696
KingBaby's Avatar
KingBaby
Hardest Setting
Old Oct 7, 2012 | 05:59 PM
  #697
0jiggy0's Avatar
0jiggy0
****in lmao at the beginning.
Sounds like racecar. Idle sounds like a car with cams.
Old Oct 7, 2012 | 07:36 PM
  #698
F2CMaDMaXX's Avatar
F2CMaDMaXX
Sounds like a car with severe running issues actually.... :/
Old Oct 7, 2012 | 07:42 PM
  #699
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
LOL @ beginning of video. While it does idle weird, the exhaust sounds good. What's that sea green colored thing in your exhaust outlet in the beginning of the video?
Old Oct 7, 2012 | 08:37 PM
  #700
KingBaby's Avatar
KingBaby
Hardest Setting
All correct one of the breather hoses wasn't on. An actually coming from test pipes the idle is no different, only after 3k does it go wild.
After actually finishing only gripes is the gaskets, actually was thinking of putting the stock metal ones back on! Also a little heads up on wrapping them in a shirt or something while putting them in....stupid dings/scratches!
The green thingy is a sock!
