PPE Longtube Headers
Old Oct 19, 2012 | 12:11 AM
  #721
KingBaby's Avatar
KingBaby
Hardest Setting
This the most important tool!
Old Oct 19, 2012 | 08:17 AM
  #722
0jiggy0's Avatar
0jiggy0
In hoping my airratchet will do mostof the work.
Old Oct 19, 2012 | 11:00 AM
  #723
sportbiketed's Avatar
sportbiketed
Probably not since there isn't much room to work with.
Old Oct 19, 2012 | 02:18 PM
  #724
terrasmak's Avatar
Plenty of odd angles , I used mine in a few places
Old Oct 20, 2012 | 07:31 AM
  #725
terrasmak's Avatar
Another sound clip, this time with the shockwave installed
http://youtu.be/XWHXwXzx2J4
Old Oct 20, 2012 | 08:40 AM
  #726
Bmurray350z's Avatar
Bmurray350z
they almost sound a little too raspy for my taste.
Old Oct 20, 2012 | 09:11 AM
  #727
0jiggy0's Avatar
0jiggy0
***** is loud.
Passanger side is super easy, on the HR at least. Drier side looks like it'll be a *****.
Old Oct 20, 2012 | 09:13 AM
  #728
Bmurray350z
***** is loud.
thats interesting. on my old DE the passenger side was a b1tch and the drivers sides we got off in 30 minutes.
Old Oct 20, 2012 | 09:16 AM
  #729
terrasmak's Avatar
If rasp is really a concern, just stick to a cat back system. Long tube headers are not something the typical limp wristed waxer needs driving around town.
Old Oct 20, 2012 | 10:16 AM
  #730
0jiggy0's Avatar
0jiggy0
Seriously. So tired of the rasp complaining. Every non american powerful car has rasp. It's not even a bad sound to me depending on the car. Avg honda fart can or ebay crap exhaust is terrible. But every beemer, maserati, and benz etc Ive heard had a raspy note. I call it character.
Anyway, passanger side is off. Question for the HR guys on the driver side, should I just disconnect the coolant lines on the driver side? They are just right in the way from what I see.
Why does the hardware kit have you remove the stock studs and nuts? Is it a pain getting the headers over the stock studs?
I didnt buy the hardware kit but I'm suprised the headers without the hardware kit didn't come with the extended wires. Their pretty much required.
Old Oct 20, 2012 | 12:15 PM
  #731
mw9's Avatar
mw9
does stepped cost more?
Old Oct 20, 2012 | 12:58 PM
  #732
0jiggy0's Avatar
0jiggy0
Only thing that changes the price is coating type. stepped vs non is the same
Old Oct 20, 2012 | 01:09 PM
  #733
juicinjake's Avatar
juicinjake
i dont know if u have the v1 or the v2, but ive got the v2 and thats pretty much exactly what mine sounds like.
Old Oct 20, 2012 | 01:13 PM
  #734
juicinjake's Avatar
juicinjake
denchan350gt put two additional resonators in his exhaust and it mellowed it out a lot. they also got rid of the annoying decel air sucking/ rasping noise that you get with an open exhaust on these headers. ive gotten used to the way my car sounds and i like it now, except for the decel sound. im thinking about trying some vibrant ultra quiet resonators just to get rid of that sound. i dont mind the rest of the rasp under acceleration at all. thats just what these cars sound like with a free flowing exhaust.
Old Oct 20, 2012 | 02:17 PM
  #735
terrasmak's Avatar
V1 single with the megaphone
Old Oct 20, 2012 | 02:55 PM
  #736
0jiggy0's Avatar
0jiggy0
Passenger lower rear corner bolt is a nightmare. Its near where the tube curls up. very tight, any tips?
Old Oct 20, 2012 | 05:54 PM
  #737
juicinjake's Avatar
juicinjake
the two in the back like that are the hardest to get to. the best thing you can do is get on it with a wrench. maybe use a backup wrench to help get it tighter, thats what i did.
the real shitty part comes in when you notice that the collector flanges dont line up well with the y-pipe. the collectors are almost doomed to leak. thats the only thing i dont like about my headers. i figured out an easy way to fix it. im gonna add two more flex sections to the xyz pipe and have it rewelded with the flanged bolted up tight, but i havent had time to go to an exhaust shop and have it done yet.
Old Oct 20, 2012 | 06:11 PM
  #738
Classy's Avatar
Classy
I fabbed up a bracket between the headers (OBX long tubes) and used a ratchet strap to pull them in and put the bracket between them, worked great and never had a problem
While I was making the bracket I took .040 lock wire and tied it between there to prevent the header from hitting the car
Old Oct 20, 2012 | 06:39 PM
  #739
terrasmak's Avatar
Mine was almost perfect with the xyz pipe
The very back bolts were done from the underside with a normal wrench
Old Oct 21, 2012 | 01:06 AM
  #740
juicinjake's Avatar
juicinjake
thats weird, derek's was out of line like mine was too. did you bolt it to the exhaust before you tightened down the bolts at the head?
