Exhaust clearance
Old Dec 6, 2012 | 08:37 AM
peter_rabbit's Avatar
peter_rabbit
Default Exhaust clearance
Yes, I searched.
Anyone else concerned about how even a stock exhaust is good inch lower than the cars unibody itself?
Ive read in a few threads that getting test pipes to help clearance with the front portion, but anyone have any experience with exhaust systems that tuck up higher than stock?
I would love to keep my stock exhaust, but would rather have a remedy.
It just barely scrapes, any tips? Aside from raising the car? And, I already take bumps at an angle.
Old Dec 6, 2012 | 08:49 AM
0jiggy0's Avatar
0jiggy0
Live with it.
Old Dec 6, 2012 | 09:06 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Originally Posted by 0jiggy0
Live with it.
Yup yup.
Stillen y-pipe and replacing the resonator with a straight pipe or a smaller diameter one like Vibrant will help but our cars are low so it's something you have to live with.
Old Dec 6, 2012 | 09:15 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
If you're running the stock exhaust, you've not a lot of options, sounds like you've slammed it past the useful point, i'd fix that or get an aftermarket exhaust with good clearance, such as a Motordyne system.
Old Dec 6, 2012 | 09:18 AM
mvp2765's Avatar
mvp2765
how slammed are you? And its an oem exhaust, not worth alot. A few scrapes here and there is no big deal.
Old Dec 6, 2012 | 09:21 AM
peter_rabbit
Not too slammed I don't think? Fronts are; 18x9.5 +12 235 40 18 Rears are; 18x9.5 -3 255 35 18 with one finger gap all the way around, fronts are at -2.0 camber, and rears are 0 camber.
Old Dec 6, 2012 | 11:32 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
If the underside of the car is scraping and you're wanting to drive it on the roads around where you are (as opposed to just looking at it) then you're too slammed.
It's not really an opinion thing
Old Dec 6, 2012 | 11:33 AM
Waiz's Avatar
Waiz
Raise your car or get a custom single exhaust made
Old Dec 6, 2012 | 04:08 PM
peter_rabbit
I understand the concept of practicality. I'm just curious if anyone with the same intentions of keeping their car at the same height had a bolt on solution.
Old Dec 6, 2012 | 04:36 PM
0jiggy0's Avatar
0jiggy0
Their solution was post 2.
Old Dec 6, 2012 | 05:06 PM
peter_rabbit
Yes, my reading comprehension is more than average. It does not help when people point out what has been covered. Good effort, nonetheless.
Old Dec 6, 2012 | 08:33 PM
terrasmak's Avatar
Just install proper height tires , and raise the car to the same fender gap you had before. You will gain almost an inch of clearance.
The other solution you can also combine with the above one. Get test pipes, cut them and raise the exhaust, little cutting and welding , all good.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
