HELP..HR vs DE cats
Ive tried searching this forum and looked all over google but i am unable to find the answer. I know the HR exhaust system out flows the DE. But i was wondering if The HR cats also out flow the DE cats. i might be picking up a cheap set of stillen headers for the HR and dont mind the extra work of swapping the studs. I wouldnt mind hfc or art pipes but i like how quiet my HKS exhaust is until i open her up. Plus i cant stand a "raspy" exhaust.
So basically do Hr cats flow better And is the inlet/outlet dimensions wider? Thank you
My answer is no, I don't have hard facts on this but I have had HR cats and DE cats right next to each other and the HR cats did not seem any bigger or too much different in shape or capacity..
HRs on the left / DEs on the right
The problem is Nissan engineered the HR cats to match the amount of backpressure needed for that particular engine. Swapping them over to a DE simply won't help- the ECM will adjust for an anomaly in backpressure and output will remain the same (while throwing a CEL at the same time). It's a familiar story...
I have both at my house I can take pictures for you...if anything
