Kinetix V+ Sound?
Old Mar 8, 2015 | 03:22 PM
Whiskers1996's Avatar
Whiskers1996
Question Kinetix V+ Sound?
I'v had it installed for about a month now but just noticed this weird sound. You can hear it clearly around 15 seconds. Once I put some pressure on V+ the sound goes away. I just checked the torque on the bolts and they are all good and no leaks from the plenum. Is this normal for this upper plenum?
https://www.youtube.com/watch?v=qwm3...ature=youtu.be
Old Mar 8, 2015 | 07:30 PM
rcdash's Avatar
rcdash
It leaks. It's plastic, low quality, like most things kinetix...
Old Mar 8, 2015 | 08:48 PM
Whiskers1996
Well, I hope its not a leak . It only stops(almost) when I press the center. Wondering if maybe its the support that is doing it?
Old Mar 9, 2015 | 07:08 PM
waldo36's Avatar
waldo36
Naw buddy you're good. I think it's the sound vibration bouncing off the middle because it is made of plastic it will flex. Mine does the same thing and I've shaved that center post out. If you had a leak with this plenum, you would definitely hear the vaccum sound.
Old Mar 9, 2015 | 11:09 PM
Whiskers1996
Good to hear , thank you. I swear I didn't hear it before even though I spent 5 mins checking for leaks after I installed it .
Old Mar 10, 2015 | 05:11 AM
JERZ350's Avatar
JERZ350
You definitely will hear the engine internals more through the V+.
Old Mar 10, 2015 | 08:08 AM
iideadeyeii's Avatar
iideadeyeii
I used silicon instead of the cork gasket to seal mine.
Old Mar 11, 2015 | 08:54 AM
kennyl5123's Avatar
kennyl5123
Don't worry, I have this plenum for over 50k miles with this sound. I actually like it that way
Old Mar 13, 2015 | 03:14 AM
Whiskers1996
Thanks everyone, appreciate the feedback.
Old Mar 14, 2015 | 09:43 AM
dsm_mikey's Avatar
dsm_mikey
Does this intake manifold make power gains over the stock upper intake manifold?
03_Track_Z
Apr 12, 2005 12:21 AM
jreiter
Feb 23, 2005 05:18 AM
sux2bu
Nov 7, 2004 08:38 PM
murrman100
Aug 30, 2004 08:49 PM
BrImSt0ne
Aug 9, 2004 07:33 AM
