Kinetix Racing Plenum Dyno's!!!!!!!!!!!!!
Old Feb 9, 2004 | 07:54 PM
  #61
MY350Z.COM's Avatar
Why was the correction factor none? Shouldn't it be set to SAE?
Not being skeptical; I just want to make sure the dyno is valid.
  #62
ChrisMCagle's Avatar
ChrisMCagle
Default Plenum
Originally posted by blue_z2003
what is plenum exactly????? i see it every were???
It's basically the top part of the engine. It is where the air goes from the intake and gets directed it to the different cylinders. In theory, more air = more power.
Old Feb 9, 2004 | 07:58 PM
  #63
syf0n's Avatar
syf0n
Frankly, I'm surprised you were able to sign up for this forum and post a comment in this thread. Congratulations.
all_bark, thanks for being a great guy and taking one for the team. It takes some serious character to ignore throngs of idiots throttling you for dynos even as you are trying to post them on the forums, as can be seen in this thread in between your original posts. Great job!
Old Feb 9, 2004 | 08:03 PM
  #64
all_bark's Avatar
all_bark
that was the way they were all presented to me but when I have some time I can do them all ANY WAY THE PROGRAM ALLOWS. Tell me how you want them. Which runs, etc, etc. I'll be happy to do all of it. For now, if you want, ignore the numbers and look at the gains, or is that skewed?
Old Feb 9, 2004 | 08:05 PM
  #65
silverstoneTT's Avatar
silverstoneTT
Like the others Id like to know what effects the plenum would have on a stock car. Glad to see though after all those pages I followed for this that the results were positive
Old Feb 9, 2004 | 08:12 PM
  #66
mchapman's Avatar
mchapman
It should be set to 3...
  #67
MY350Z.COM's Avatar
Cool, can you post the same chart but with RPMS.
And set the CF to SAE.
Also, set smoothing to 3 please.
Old Feb 9, 2004 | 08:14 PM
  #68
ares's Avatar
ares
Veteran
awesome work man. I am curious to see the numbers on a stock car, not disputing yours in any way. just like to get a better idea of what they will do on my own setup.
Im sure it will happen eventually after its released.
Old Feb 9, 2004 | 08:43 PM
  #69
was wesman's Avatar
was wesman
The key is that all the dynos that are being compared are set to the same correction factor. It doesn't matter if it's set to1.00 or 1.05....as long as it's the same for all of them you will be able to see the gains. While it will affect the actual peak numbers it will affect them the same all around.
Does that make sense ?
--wes
Old Feb 9, 2004 | 08:44 PM
  #70
wren57's Avatar
wren57
My engine is bone stock, and I should have my plenum as soon as anyone... I won't be dynoing it, but the butt dyno is fairly accurate.
There is a dyno approx 1 hour from here I wouldn't mind going to. They charge $80 for 1 hour of dyno time. I would certainly go get the car a few base pulls, then some post-plenum pulls on a STOCK Z. I'm poor, is the only problem... I could adopt all_bark's method of taking donations, but won't consider this until I have my plenum AND talk to the shop tomorrow to confirm pricing.
http://www.walkerdynotune.com/mainsite/dynoservices.htm
Old Feb 9, 2004 | 08:52 PM
  #71
Z4KR's Avatar
Z4KR
Great job Joe. Are you going to show up at the next SD meet (this Saturday) so we can check out the plenum in person?
Old Feb 9, 2004 | 09:02 PM
  #72
all_bark's Avatar
all_bark
this saturday is valentines day and believe it or not my girlie is WAY more important than the Z!
Old Feb 9, 2004 | 09:04 PM
  #73
FairladyZ's Avatar
FairladyZ
The dynos are awesome. Is that SAE rwhp/rwtq like asked above?
Old Feb 9, 2004 | 09:11 PM
  #74
BlueDragonZ's Avatar
BlueDragonZ
Sshhh don't say that, your Z might be listening.
Seriously though, take care of business, after this whole ordeal you deserve it.
Old Feb 9, 2004 | 09:12 PM
  #75
92hatchattack's Avatar
92hatchattack
just kinda cusious...... has there been a dyno of the test pipes by them selfes????
can anyone estimate the power of a test pipe/kinetix combo???
screw the sniffer... ive got my ways around it!!!! i want every last pony
so what u all think???
Old Feb 9, 2004 | 09:16 PM
  #76
all_bark's Avatar
all_bark
someone asked for this
good night all!
Old Feb 9, 2004 | 09:18 PM
  #77
all_bark's Avatar
all_bark
oh yea,
the first is the baseline that includes
injen/pop charger hybrid full cai
borla true dual
ur pulleys
grounding kit
the second
all the above plus the Kinetix Hi-Flow Cats
the third
all of the above plus the Kinetix Plenum
the numbers are now sae and smoothed to 3!
Old Feb 9, 2004 | 09:20 PM
  #78
rodH's Avatar
rodH
WOW, so we are looking at a 17.5 hp gain there??
Old Feb 9, 2004 | 09:22 PM
  #79
rodH's Avatar
rodH
roughly 9 HP for cats, and 8.5 for plenum??
Old Feb 9, 2004 | 09:47 PM
  #80
AmyCroft's Avatar
AmyCroft
Default Looking Good Guy's - Good number's
Nice work All_bark and LSD Unique....
Very nice increases in HP and Great tourqe Numbers...
I can base line my Stock (Engine wise) Z and then put on a production LSD Unique Plenum...
I'll use the local Dynojet in Huntington Beach...
I'll test in 4th (5AT - Stock Rear End)
And make no changes other than Plenum ! About March Time frame.
Still sorting out Fethering/Bounce issues
Cheers Amy -
oh yea,
borla true dual
ur pulleys
grounding kit
the second
the third
P.S. LSD Unique rear Camber Rod's to be Replaced with ******** Camber Rod's
Front Adjustable Camber Arms TBD. Plus Koni Adjustable Struts and Shocks.
