Kinetix Racing Plenum Dyno's!!!!!!!!!!!!!
Old Feb 10, 2004 | 10:38 PM
  #141
little_rod's Avatar
little_rod
Real refreshing. Saw the long trend, and not a negative post on dynos yet, lol. I was expecting to read alot of them in this long of trend. Wish the same standard was held in all of our trends, at least giving respect to the people responsible for the results. Interesting that all associated with Crawford was said to have tainted results, yet any associated to kinetix doesn't have the same problem.
Oh well, I have no connection to either, and like them both. Can't we just all get along??
Old Feb 11, 2004 | 05:08 AM
  #142
myG35zx's Avatar
myG35zx
The G has the rear support. The front may actually lead to more oversteer - I thought. But I'm no engineer and have no idea. LOL
But I want the plenum. If a STB is availble, I may buy, I may not. But regardless of the infamous dip in the plenum. To me it adds character! :P
All-Bark
WooHoo!
Now I will wait for my valve cover gasket (mine is leaking, a lot) and my new plenum.
Old Feb 11, 2004 | 06:02 AM
  #143
Ak1nza's Avatar
Ak1nza
Originally posted by lsdunique
We had put a lot of thought into a version without a dip, especially for the G35 owners.
I think though we are going to seriosly explore the option of a G35 strut bar first, that will work with our plenum.
Would there be interest in a G35 strut bar? and a G35 strut bar/plenum package?
In that case, how about an FX strut bar so we can keep the dip!
Honestly though, G drivers won't really see much improvement with a strut bar because the front end is quite stiff as it is. I have driven it before. I doubt it would be economically feasible to even consider designing one for the FX (although it would be nice).
Wouldn't it be much easier just to manufacture a plenum without the dip though? Not only easier but cheaper than the cost of designing a proper strut bar to fit into the G? Plus you won't have to go through the problems of moving the HID ballasts and such on the G.
Just my .02 again. Since a G strut bar/plenum package doesn't apply to me I would prefer to have a plenum without the dip.
Old Feb 11, 2004 | 06:20 AM
  #144
wren57's Avatar
wren57
The whole point of having the dip is so Z owners can keep their stock strut bar (a huge issue with many, including me). Don't like the dip? Well, there is a solution for that too. It is called Crawford.
Old Feb 11, 2004 | 06:41 AM
  #145
Wedge's Avatar
Wedge
Maybe in the future, for the G owners, there can be some sort of piece developed that simply fills in the dip. The plenum would stay the same, but this hollow piece which would conform to the dip underneath and smooth out the appearance on top and would simply attach in the plenums groove (dip)..........just thinking out loud.
Old Feb 11, 2004 | 06:46 AM
  #146
manrey's Avatar
manrey
Originally posted by PoWeRtRiP
man your running pretty lean there might wanna be careful until you get that fixed, a point to be made is that the reason why these plenums produce such good gains up top is because of how much they lean out the cars a/f. leaning out the fuel makes more power, if its possible all-bark might we arrange a post ts reflash dyno session to see what it makes after you get the a/f right? plus the tuning may make even better gains. im sure we could find some members to throw down $$ to help out, i would for sure.
This always comes up, the fuel mappings should maintain the a/f ration in the car, this is the job of the ecu.
No matter how lean you think it is, its maintained at a level just under pre-ignition. if it detects knock, it will retard the ignition timing thus reducing the chance of detonation. As long as you dont hear it knocking, i think your ok.
at least this is my understanding of general ecu's in cars.
Old Feb 11, 2004 | 07:13 AM
  #147
FLY BY Z's Avatar
FLY BY Z
There is a point where the ECU cannot adjust anymore as the incoming air is more than the range the ECU can recognize. There is also an ideal AF ratio for NA right around 13.5 or so, IMO. Just because you aren't knocking doesn't mean your AF is ok. The knock sensor can pull timing but that will also hurt performance. It is better to have everything right.
Old Feb 11, 2004 | 07:31 AM
  #148
MustGoFastR's Avatar
MustGoFastR
Stillen is coming out with a strut bar for the FX soon, but it wouldn't need to utilize the dip in the plenum. We have a lot more clearance above the plenum in the FX, as the engine sits lower in the bay; The Stillen blower will even fit with no hood mods (also coming soon for the FX).
Pardon me for saying, but that's just silly. The whole point of anyone wanting a dippless plenum is that it might give even better performance without it (which isn't even known). Wanting a dippless plenum for aesthetic reasons is pointles, since in the G or FX, you'd never see it under the engine cover. The only problem is that the plenum doesn't incorporate the rear mounting holes for the G/FX engine cover, but it shouldnlt be too difficult to fab something.
Honestly, I don't see any reason for a G or FX owner to buy the Kinetix over the Crawford other than personal preference unless it costs a fair amount less or is proved to have better gains (I think all the proposed comparos should settle that if anybody gets around to doing it). I don't see the big deal in keeping the factory plenum at all; you're not likely to ever want it again.
Old Feb 11, 2004 | 08:25 AM
  #149
KJY9's Avatar
KJY9
Originally posted by 350zdanny
all_bark -
I don't know if you got my last PM, but if you don't mind, could you send me the two files from the post-cat baseline, and the post-plenum final run?
Dan
Did you get the files emailed to you?
I didn't and am wondering why, as they're small files and not tough to email.
Old Feb 11, 2004 | 08:35 AM
  #150
al503's Avatar
al503
Originally posted by MustGoFastR
Honestly, I don't see any reason for a G or FX owner to buy the Kinetix over the Crawford other than personal preference unless it costs a fair amount less or is proved to have better gains (I think all the proposed comparos should settle that if anybody gets around to doing it). I don't see the big deal in keeping the factory plenum at all; you're not likely to ever want it again. [/B]
I have to respectfully disagree with you on this one. Although I'm sure that there will be other plenum offerings in the next few years, I could see getting the Kinetix, using it for a couple, three years, then selling it used to recoup some of the costs. It's not considered a wear item so if you could conservatively get 1/2 of what you paid for it, you're getting some serious bang for your buck.
You can't do that with the crawford unless you keep the stock plenum (+$200) or have a potential buyer send you his stock plenum to trade for yours.
Old Feb 11, 2004 | 08:36 AM
  #151
350zdanny's Avatar
350zdanny
Nah I contacted him a few times and asked in a few threads. I'm sure he's just busy with questions and plenum stuff. Yea dynojet run files are only 5 or 10kb.
dan
Old Feb 11, 2004 | 01:26 PM
  #152
KJY9's Avatar
KJY9
dan
Hmm either that or he doesn't want anyone else seeing them for whatever reason ??
Old Feb 11, 2004 | 01:41 PM
  #153
syf0n's Avatar
syf0n
Who gives a ****? Seriously guys, it's just some dyno files. Give it a friggin' rest.
Old Feb 11, 2004 | 01:57 PM
  #154
350zdanny's Avatar
350zdanny
I was just answering the dude's question. And if you read, if can read, you'll see I gave him the benefit of the doubt. What's your ****ing problem?
Old Feb 11, 2004 | 02:45 PM
  #155
KJY9's Avatar
KJY9
I'd like to do a compare with my files smartazz! WTF are you?!?
Old Feb 11, 2004 | 03:11 PM
  #156
D_Nyholm's Avatar
D_Nyholm
wow, a bit testy in this thread!!! Drop the testosterone down a notch!!!
Old Feb 11, 2004 | 03:15 PM
  #157
rouxeny's Avatar
rouxeny
Relax with the 'tude please.
Old Feb 11, 2004 | 04:16 PM
  #158
Apexi350z's Avatar
Apexi350z
Charter Member #50
give him some time, he is probably occupied by his gf right now
Old Feb 11, 2004 | 04:20 PM
  #159
350zdanny's Avatar
350zdanny
I don't want you guys to get the wrong idea and I hope you're not jumping on me. I'm not in any hurry to get them. He was just oblivious to my question when he responded to me earlier. I just wanted to make sure he knew I wanted them. I'm not looking to validate or refute what he said. I was gonna put them in my own archive and compare them to the ones I did for my own edification.
That's it. So all of you please calm down and don't blow this out of proportion. It is not an issue.
Dan
Old Feb 11, 2004 | 05:20 PM
  #160
Ultimateone's Avatar
Ultimateone
Its not an issue but everyone just loves to jump down everyone's throat at any chance and makes many of you seem immature....
Competition is great and makes things exciting but hou.ding people for this and that gets old real fast.
I just want the damn plenum anyways
