Isis single exhaust
Old Jun 1, 2015 | 01:33 PM
Godfoot's Avatar
Godfoot
Originally Posted by Waiz
Exhaust looks good, would suggest a bumper tuck
I saw it on the CZP site the other day
Thank you so much! I appreciate that! I'm still considering it, I want to sleep on it until I'm certain before I start drilling
Old Jun 2, 2015 | 10:36 PM
Waiz's Avatar
Waiz
Mine is actually just ziptied to the rear bumper brace
Old Jun 3, 2015 | 01:11 PM
Godfoot's Avatar
Godfoot
Well if that's all you had to do, I may look up a DIY thread and take a stab at it !
Old Jun 4, 2015 | 01:26 PM
90nissanS13's Avatar
90nissanS13
Waiz, Super nice Z ( RS concept clone). Any plans to cut the louvers in the hood?
Old Jun 5, 2015 | 06:14 PM
Waiz's Avatar
Waiz
Thanks
I have tossed around the idea of cutting my hood for years but I think getting a aftermarket vented HR hood is probably what I am more leaning towards.
Old Jun 5, 2015 | 10:41 PM
90nissanS13
Awe, c'mon now. The HR hood would ruin the whole theme.
Old Jul 20, 2015 | 09:27 AM
90nissanS13
FINALLY
Old Jul 20, 2015 | 07:36 PM
90nissanS13
Ready for the wideband sensor.
Old Jul 20, 2015 | 08:25 PM
nizmo_0385's Avatar
nizmo_0385
Nice. In the youtube clips im hearing decel rasp as rpm drops can you confirm?
Old Jul 21, 2015 | 05:51 PM
90nissanS13
If no one else replies, I'll give you feedback after the weekend when I install mine. Although, I'd like to put some mileage on it and get familiar with the sound before I share my opinion.
Old Jul 21, 2015 | 08:48 PM
90nissanS13
No polished-stainless for me.
Old Jul 29, 2015 | 08:54 AM
90nissanS13
Waiting to install, as long as it doesn't rain all weekend...again.
Old Jul 29, 2015 | 11:28 AM
90nissanS13
The camera doesn't quite duplicate our binocular vision but, here is my A\F gauge mounted in place. Sitting in the seat you can see 1-8k just fine.
Old Jul 30, 2015 | 12:19 AM
90nissanS13
Default Installed: first impression
Well, I decided to install the exhaust in the middle of the night as I was a bit anxious. If on only knew...
When they say "you get what pay for", it's pretty much an obvious outcome for the items you pay the least for. I'll keep this short and too the point.
After the oem exhaust finally came off the car, the ISIS/Megan Y-back went on pretty straight forward. I noticed some clearance issues prior to tighten the fasteners but, that clearence looked good when everything was set...or so I thought. I started the engine and idled for about 20mins, re-tightened the fasteners and look the exhaust over again.
After a ten minute drive I encounter two problems.
-the outlet contacted my bumper covered and melted the plastic. I now have a melted bumper cover and plastic stuck to the exhaust. Great...
-the mid-resonator contacts the driveshaft! I can hear a nice sound of scrapping during rev-matching downshifts. FML
Back to the drawing board. I'll have to media-blast the tip again, repaint and trim my melted bumper.
Old Jul 30, 2015 | 02:47 AM
nizmo_0385's Avatar
nizmo_0385
Damn that sucks. As for the tip and bumper i think that can happen with any exhaust it happened with my agency power single as well as my current tomei however the tomei is adjustable so i can keep it off my bumper. What i am suprised about is drive shaft clearance that really blows
Old Jul 30, 2015 | 03:02 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
What part is hitting your drive shaft wtf. Can you flip your resonator section aka is it installed upside down?
Old Jul 30, 2015 | 12:27 PM
90nissanS13
Highlighted by the yellow circle, this is the area where the contact to the driveshaft occurs. I going to see if I can turn the pipe away from the driveshaft from the flange but, there is very little movement allowed. I'm certain it's not installed backwards or upside down. If it was to be flipped, it would point straight out the rear. The angles are partially made up at the flanges. The flanges are welded at specific angles to make up the overall profile of the single exit.
Old Jul 30, 2015 | 12:37 PM
  #38
90nissanS13
In regards to the tip melting my bumper cover I'm sure it could happen with others but, it shouldn't. The hanger closest the exit it welded on and doesn't make life easy for adjustments. I'll live with that. I ended up trimming the center section of the bumper cover out. I basically went from the tangent point of each arch in a straight line across. The clearence now will be sufficent. Not my preferred outcome.
The rear section will come off again to be media-blasted again and I will trim the length of the tip(it's obnoxiously long), then it'll be repainted. Sigh...
I usually spend money on parts when I don't want to make them or rework them, and this happens.
  #39
nizmo_0385's Avatar
nizmo_0385
Could get a hammer and dent it. Surely not ideal but maybe only option
Old Jul 30, 2015 | 12:52 PM
  #40
dboyzalter's Avatar
dboyzalter
Strait pipe that. Thats really messed up. I was thinking I was correct all day and thought you were going to write back and say in a genius... Guess im still of only average to questionable intelligence.
