3.5'' Intake
Old Jul 21, 2015 | 03:27 PM
Whiskers1996's Avatar
Whiskers1996
Default 3.5'' Intake
Decided to make a 3.5'' intake and this is just a short write up and parts used.
Parts-
3.5'' 40* bend, 5.7''(spectre) - $20
3.5'' strait, 6'' (spectre) - $16
Breather filter $10 OR Vacuum sensor adapter(spectre) $10
Metal MAF adapter(ebay)(make sure to have bolts/nurs)- $16
Filter of choice with 6'' neck- about $50+
Velocity stack of choice - $15+
Clamps and couplers - about $60
Depending on the Vstack size,maf housing,and tb the couplers and clamps will vary but you can get a general idea from the pictures. I used (2) 3.5'' , (2) 3.5''-3'' couplers, (2) 3'' and (6) 3.5'' clamps. That is with the NWP TB,stock maf, and 3.5'' vstack.
Notes~~~
~My filter is 7'' long and because of that I had to cut about 1/2 an inch on the strait pipe to make it fit.
~At first I used a vacuum sensor adapter but at the angle I drilled the hole it was to far to the right and decided to try using a breather filter(with a new pipe) and was much easier to install.
~ For now there is no heat shield or a support brace for the intake as i'm waiting to be re-tuned with a larger maf housing which will make the intake shorter overall(and possibly changing the filter size to something smaller) and then I will deal with making the shield and support.
Attached Thumbnails 3.5'' Intake-20150721_164453.jpg   3.5'' Intake-20150721_164507.jpg   3.5'' Intake-20150721_164528.jpg   3.5'' Intake-20150721_164618.jpg
Old Jul 22, 2015 | 09:24 PM
terrasmak's Avatar
I think I am looking at a stock MAF housing that is 65mm and it the actual problem
Old Jul 23, 2015 | 08:53 AM
mr. sparco's Avatar
mr. sparco
https://my350z.com/forum/intake-exha...rs-etc-17.html
I've ran both 3.5 and 4".
Old Jul 23, 2015 | 11:08 AM
Whiskers1996
@terrasmak, I have an airaid 3.5'' housing waiting to go in,I got DC headers being installed after some body work next week and then off to zfever/feverracing for a tune.
@mr.sparco, I thought about the 4'', but after seeing pics it just 'looks' too big and the 3.5 seemed pretty cramped to me already.
Old Aug 2, 2015 | 12:06 PM
bchalks's Avatar
bchalks
Do 3.5" intakes actually produce more power? Considering a furookie 3.5" to replace my z tube K&N filter setup. With a 5/16 spacer and header back exhaust plus retune, will the 3.5" intake help at all?
Been researching for awhile, just can't find solid answers.
Old Aug 2, 2015 | 02:43 PM
Whiskers1996
https://my350z.com/forum/intake-exha...stalled-4.html Here you go. Yes, they have been proven to show gains with the other supporting na mods.
Old Sep 2, 2015 | 03:01 PM
Whiskers1996
Here is the intake now with the jwt filter/shield and new maf housing.
Old Sep 6, 2015 | 03:09 PM
terrasmak's Avatar
Interesting setup, what MAF housing is that ?
Old Sep 6, 2015 | 05:19 PM
Whiskers1996
It is an Airaid MAF housing. http://www.airaid.com/maf_adapters.aspx
apex locator
Jul 23, 2021 02:27 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
