Catalytic Converter Question
Old Nov 19, 2015 | 09:22 AM
ctanakaya's Avatar
ctanakaya
Default Catalytic Converter Question
Hey guys,
First post on this thread and a noob to the forum.
Long story short is my cats have failed and I dont know if I should get stock used cats or get something else like Berk HFC.
Money is kind of tight right now so I need some advice on which road I should take.
Also this will be going on a stock 2003 350z exhaust because the previous owner decided to weld the stock cats onto a cheap aftermarket exhaust.
Thanks guys
-Chris
Old Nov 19, 2015 | 09:24 AM
turboed350z's Avatar
turboed350z
Oem cats are aeound 200. HFC are about 350. If money is tight, just go with oem.
But with used parts, theres a chance of it failing again. Personally i would save up and go with the hfc.
Old Nov 19, 2015 | 09:26 AM
travlee's Avatar
travlee
Master
check the classified section for some used ones for now
boom
https://my350z.com/forum/exhaust/607...omponents.html
(might want to confirm they came from a 03-06)
Old Nov 19, 2015 | 05:42 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Chris, being that you're in California, be wary of trying to get HFCs past the visual inspection when going in for bi-annual smog.
You might, you might not pass because technically speaking aftermarket cats are NOT legal unless certified by CARB. To my present knowledge, no high flow units are legal for substitution. (I welcome anyone pointing me in the direction of any that ARE exempted by CARB.)
And yes, that's regardless of sniffer results. There was another forum member recently who got a refuse-to-test due to aftermarket plenum spacer even though it was likely he would have passed the sniffer.
The main question: Is the ever-so-slight uptick in horsepower worth the hassle? (I know people who put the OEMs back in for testing then remove once done.) Only you can decide that.
Given that, I'd stick with OEM.
Old Nov 19, 2015 | 06:10 PM
ctanakaya's Avatar
ctanakaya
boom
Definitely saw this the day it went up and gave him a quick call but no response. Sent over a message so fingers crossed. Thanks!
Old Nov 19, 2015 | 06:12 PM
ctanakaya's Avatar
ctanakaya
This was very helpful thank you!
Will probably go with some OEM cats
Old Nov 22, 2015 | 09:15 AM
guitman32's Avatar
guitman32
Makes me so glad I dont live in a CARB state...
Old Nov 22, 2015 | 02:14 PM
travlee's Avatar
travlee
Master
may be out of town for the holiday
Old Nov 22, 2015 | 02:29 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
http://www.kinetixracing.com/kinetix...onverters.aspx
I got 49 states but California ain't one.
Miguel Albanez
May 4, 2017 12:58 PM
gotama
Apr 12, 2016 08:10 AM
carid
Oct 22, 2015 06:30 AM
Evilest-ninja
Oct 21, 2015 07:23 PM
