NWP 75MM Throttle Body Problems
Old Aug 5, 2020 | 09:06 PM
Zion_Hazard's Avatar
Zion_Hazard
Default NWP 75MM Throttle Body Problems
I just installed the 75MM throttle body on my 2004 350z (DE). I have done all the resets and relearn steps that the instructions say. No codes what so ever yet I’m having a small yet annoying problem. The throttle body remains open for about 1 second after I release the gas pedal. Anyone deal with this problem? If so what was the fix to it.
Old Aug 18, 2020 | 06:53 PM
ntwillie1's Avatar
ntwillie1
Did you ever figure this out? I want to get the same throttle body and found your thread as I was doing some research.
also, any issues w hood clearance? Thanks in advance.
w
Old Sep 23, 2020 | 12:43 AM
g0lfball3R's Avatar
g0lfball3R
Not sure with this application. But with electric throttles I worked with, you needed factory based scan/code software to really re-adapt the throttle. Maybe with this it’s not as involved. But do you need a retune if it’s a bit larger then stock?
Old Sep 23, 2020 | 02:30 AM
DarkZ03's Avatar
DarkZ03
100% P&P I didn't even do the relearn and mine works flawless.
Old Sep 23, 2020 | 03:18 AM
g0lfball3R's Avatar
g0lfball3R
oh, so it’s maf housing increase & bigger injectors you really need retune. 75mm is not too much bigger, but helps. I wish it bolted directly & didn’t need stupid adaptor.
I’m adding the ISO thermal Aramid & copper throttle heater manifold projects. Prob adding 75mm kit too.
Old Sep 23, 2020 | 07:30 PM
DarkZ03's Avatar
DarkZ03
Yeah the adapter is ugly, I have the CZP adapter and it's better than Z1 and NWP IMO, but still ain't pretty. Will probably end up removing when I go FI, and just polish my OEM one.
Old Sep 23, 2020 | 08:12 PM
g0lfball3R's Avatar
g0lfball3R
I saw some guys drill & tap holes for it in the plenum neck.
p.s. I cut 4 of the inner support collars off plenum lid (shift tech clone) with the iso thermal stuff & it’s doing great! Intake noise is louder, no collars in the way. **** the spacer for me. Now I might get UpRev.
Old Sep 23, 2020 | 08:58 PM
DarkZ03's Avatar
DarkZ03
Uprev is nice, I got it. Running the Velocity manifold though, stock manifold is lame, too many fasteners.
JAM3Z
Dec 17, 2009 06:00 AM
silver350tn
Aug 21, 2008 06:14 PM
fklentz
Jul 18, 2008 03:13 PM
itsjoshufocker
Apr 1, 2005 01:35 PM
