Which Exhaust?
Old Apr 2, 2004 | 07:39 AM
robcassell's Avatar
robcassell
Question Which Exhaust?
OK so since the search engine is down, I am trying to figure out which exhaust will give you the most bang for your buck and the most power. Of course sound should also be factored into it. I saw this article on the internet:
http://www.sportzmagazine.com/exhaust.html
Does anyone have the results of this or a link? Or does anyone have any feedback on what exhaust they prefer or not.
Old Apr 2, 2004 | 09:23 AM
ZLover4Life's Avatar
ZLover4Life
Borla made the most power.
I also think Borla sounds the best... not too loud, but definately recognizable.
Old Apr 3, 2004 | 01:44 AM
DanF's Avatar
DanF
http://www.clearimageautomotive.com/350Z.htm
What do you think?
Old Apr 3, 2004 | 04:15 AM
350 PILOT's Avatar
350 PILOT
DON'T TRUST SOUND CLIPS!
Boral produced the most HP and is one of the cheaper. Lots of pieces and lots of arguments both for and against.
Old Apr 3, 2004 | 04:24 AM
AndyB's Avatar
AndyB
Default Borla
I did a little reading before I bought. The Borla was my choice.
Pros: Most power, true dual design w/ crossover pipe, deepest sound, dual tips like stock (but better made), heavy duty stainless construction, lighter than stock exhaust, lifetime warranty, not too loud
Cons: More pieces than most other kits, can take longer to install, some people fear more pieces = more leaks, not loud enough for some tastes.
I think a few of the earlier Borla kits had leak problems and that did a lot to cement the "borla leaks" idea. XX Tuning has installed the Borla several times and they say they like the kit and and no problems with aligning the parts or leaks.
My Borla has been on for about 4K miles now and I love it.
Alot of it depends on want you want. If you want a raspy exotic sound, this may not be the exhaust for you. If you want a deep rumbling sound maybe it is. If you want to keep the dual tips and back em up with a real dual system, the borla is good. If you want a single large exhaust on one side look elsewhere.
That's my $0.02.
Old Apr 3, 2004 | 10:09 AM
DanF's Avatar
DanF
They may have produced the most power up to the point the test was conducted. But there is always room for improvement. That is partly the reason we waited longer than most to introduce an exhaust system. We just need to get a couple out there and I'm confident the consensus will change.
Old Apr 3, 2004 | 02:55 PM
mplc's Avatar
mplc
What is the HP increase with the Borla Exhaust?
Old Apr 19, 2004 | 03:03 AM
guido51's Avatar
guido51
I'm italian , live in Florence , and is the first time in this very interesting forum ; all the best to everybody.
My questions :
Does Borla True Dual Cat Back System fit to my new 350Z , european setup ?
I'm deciding on Borla after having read your interesting posts about exhausts systems.....
Old Apr 19, 2004 | 04:56 AM
picass's Avatar
picass
Default re
My questions :
Ciao Guido,
finalmente un altro Italiano in 350Z..., io sono un ex possessore di S 2000 adesso devo prendere un 350Z, dopo essere passato da una Evo VII.
Il dual sistem è il migliore sistema di scarico(più HP) per la 350Z, stillen e borla sono i migliori, sul dual lavora anche la 5zigen e la HKS, sempre su diametri di 2,5 inch (63,5mm).
ti lascio la mia mail poliatt@yahoo.it
Old Apr 19, 2004 | 05:11 AM
ares's Avatar
ares
Veteran
another test showed borla as the least.
Old Apr 19, 2004 | 02:31 PM
Philly Z350's Avatar
Philly Z350
So danf ....how much for that exact set-up ....it sounds sick!!!
Old Apr 19, 2004 | 03:01 PM
DanF's Avatar
DanF
We will be moved into our new shop by the end of the month. The lift is being moved on the 27th. Once we are set-up we will be pulling the system off of the test car. I'm hoping to have all systems and prices complete by the 3rd week in May.
Stay tuned for a forum speacial. Thanks.
Old Apr 19, 2004 | 05:01 PM
robcassell's Avatar
robcassell
i have read that stillen is overall better than the borla....i read the borla actually loses power in the lower band....
Old Apr 19, 2004 | 05:29 PM
PainProphet's Avatar
PainProphet
Borla (car 2) = 8.2 Hp - 2.7 ft/lbs torque (peak values)
A top end system. Little HP increase until the 5600 rpm to 6500 rpm range. Lost HP & torque below 1800 rpm. 60mm (error actually 58mm). Weighs 52lbs. 1 million mile warranty. Installation - Hard (17 pieces)
5Zigen (car 2) = (-3.4) Hp - .02 ft/lbs torque (peak values)
Lost Hp, no real torque gain. Most expensive. Loudest. 58mm pipe. Lightest @ 25lbs. 1 year Warranty. Installation - Medium
Stillen (car 1) = 8.1 Hp - 7.3 ft/lbs torque (peak values)
Hp and torque increase starting at 3000 rpm to redline. Lost a little HP & torque below 1800 rpm. 60mm pipe. 74lbs - 10lbs heavier than the stock system. Lifetime Limited Warranty. Installation - Easy
Injen (car 1) = 7.6 Hp - 5.1 ft/lbs torque (peak values)
Small torque loss at 2800 rpm. Torque gain starts at 3300 rpm. Small Hp increase starts at 3300 rpm, max Hp from 5800 rpm to redline. Major loss in Hp and torque below 2200 rpm. 49lbs.
1 year Warranty. Installation - Easy
Nismo (car 1) = 6.3 Hp - 4.5 ft/lbs torque (peak values)
Torque increase starting at 3000 rpm. HP increase 4800 rpm to redline. No power losses below 1800 rpm. 54lbs. 3 years,
all this is from the sport z dyno tests a while back
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
