HELP ME GUYS! 911 Crawford Plenum install gone bad!
Old Apr 30, 2004 | 04:13 PM
DM350Z's Avatar
DM350Z
Default HELP ME GUYS! 911 Crawford Plenum install gone bad!
I just put my ver. 1 on the 350z and this baby wont idle at all, keeps tryin to stall, and after a few minutes the oil light comes on BUT the oil pressure is fine. I reset the ECU, unhooked the battery and thought it reset, atleast everything else in the car reset, PLEASE help, need car drivable in 2 hours, call my cell if you have to~
-Dave
4108086706
dm350z@msn.com
HELP!
Old Apr 30, 2004 | 04:25 PM
Gmike's Avatar
Gmike
This sure sounds like a vacuum leak. Tighten the bolts from the inside to the outside.
To locate the vacuum leak, use a spray bottle of water around the gaskets and fitting, helps amplify the sound of the leak.
Good luck
Old Apr 30, 2004 | 04:29 PM
SQUILL's Avatar
SQUILL
Default Re: HELP ME GUYS! 911 Crawford Plenum install gone bad!
-Dave
4108086706
dm350z@msn.com
HELP!
dont know if this will help or not as ive never heard of your problem with the crawford plenum (i agree with Gmike)but here is a link for proper ecu resetting as disconnecting the battery does nothing. Good luck!
http://www.technosquareinc.com/350reset.htm
Old Apr 30, 2004 | 04:35 PM
DrVolkl's Avatar
DrVolkl
Did you transfer that little rubber vaccuum plug on the stock plenum over to the new one?
Where you careful with the throttle body...and did you make sure to NOT disconnect it?
Old Apr 30, 2004 | 05:05 PM
DM350Z's Avatar
DM350Z
I only diconnected the plug from the throttle body, I wasnt supposed to?
Old Apr 30, 2004 | 05:06 PM
DM350Z's Avatar
DM350Z
Also, the 2 10mm bolts that were supposed to plug the 2 unused bolt holes in the lower part of the plenum, where they important, cuz I just realized I forgot that part
Old Apr 30, 2004 | 05:27 PM
spdu4ia's Avatar
spdu4ia
yea they are important... you just left two holes for air to escape!
Old Apr 30, 2004 | 05:33 PM
SQUILL's Avatar
SQUILL
lol yep tell tale signs of vacuum leak. did that do the trick ?
Old Apr 30, 2004 | 05:36 PM
DM350Z's Avatar
DM350Z
Well I didnt get any short 10mm bolts to fill the holes, will the stock 10mm ones fit, even though they are long?
DrVolkl's Avatar
DrVolkl
Yeah, you're gonna wanna plug those up.
You know, there's directions with pictures at crawfordz.com....might wanna check that out.
Old Apr 30, 2004 | 07:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
i feel your pain man...but...wow..this thread is kinda funny. Also, make sure to put the rubber cap on the nipple on the fron left side of the plenum...that is another common air escape point that people overlook. To the rubber cap off your stock plenum
Old Apr 30, 2004 | 07:29 PM
fdao's Avatar
fdao
That's your most likely culprit. I had the same thing happened to me with V5 . Did not take my time with the install and forgot the 2 10mm bolts. Scared the crap out of me!
Old Apr 30, 2004 | 08:39 PM
DM350Z's Avatar
DM350Z
Ok, got it workin fine, well I think. She idles now fine like before BUT my Oil Pressure is only reading between 5 and 10 PSI at idle, and about 30-35 psi while driving, or accelerating. I am pretty sure it used to be alot higher during both conditions. I will try resetting the ecu one more time to see if that fixes it, OH and when I made a hard stop my oil pressure dropped to 0 and the oil light came on for a moment and then went out, but scary nonethless when I have oil in the car.
Lemme know what you guys think.
-Dave
dm350z@msn.com
Old Apr 30, 2004 | 08:51 PM
SQUILL's Avatar
SQUILL
-Dave
dm350z@msn.com
Hey dave let me know how you like the new crawford plenum i ordered mine a few days ago. as far as oil pressure goes i dont know what would cause that now? would a vacuum leak in the plenum cause oil pressure problems??
Old May 1, 2004 | 07:06 AM
peptidbond's Avatar
peptidbond
-Dave
dm350z@msn.com
I highly doubt that this issue is tied to your plenum install or ECU reset. Unless, that is, you dropped a bolt down the intake manifold. The oil pressure should be your TOP concern. Change your oil now. New filter and a new 5 quarts of oil. Then check your pressure after the car has warmed up. If the pressure is fine, then drive for exactly 1000 miles. Stop and change your oil again. Measure the old oil. If you have less than 4.5 quarts, then you likely have a oil consumption problem. Keep repeating the above until you have a good idea of the consumption per 1000 miles. If it seems like a lot, then take off all your engine mods and get your car to the dealer pronto. I don't want to scare you, but they will ask you to repeat the same. If they confirm it, you will be getting a new engine (most likely).
The oil problem is something serious that needs to be addressed. I think you just happened to stumble across it when you were doing this work. The source of the issue could be something else, but it is worth the $25 for an oil change to be safe.
The problem could end up being something else and something small, but you need to treat it seriously until you know for certain. Never assume bad oil pressure is nothing to worry about.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
codek
Sep 28, 2015 03:03 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
