Digimoto and CAI
Old May 3, 2004 | 11:29 AM
all_bark's Avatar
all_bark
ran it again and intake temps are consitantly 4-6 degrees hotter than outside air temp. that is all.
my air flow meter climbed to 150+ today when i really hit it hard. how should one interpret those numbers!?!????
Old May 3, 2004 | 11:33 AM
Alang's Avatar
Alang
I have a stock air box. So I'll run the numbers on the way home tonight. I just read the post about modifying the AEM into a short ram. Since I have one sitting in my garage, I might do that this weekend and try the numbers again.
Old May 3, 2004 | 12:39 PM
ares's Avatar
ares
Veteran
just curious, but I had the active reading on %load, anyone hit 100%?
it idles at like 24ish, but even in 2nd or 3rd gear, pedal to the floor, I get 93% 94 tops.
an extra 7% power would be nice.... anyone hit 100%, is it just a cailbration thing or is the ECU really only hitting 93% output?
Old May 3, 2004 | 05:10 PM
Alang's Avatar
Alang
OK, here are my results from the drive home today.
Ambiant Air - 93
Intake temp - 99
Coolant - 190-192
It was pretty consistant. I did some time at 60, 70 and a little at 80. At 60, the intake was between 99 and 102. At 70, it was pretty solid at 99, and 80, it went between 99 and 98.
This is with stock air box and kinetix plenum
Old May 3, 2004 | 05:33 PM
ares's Avatar
ares
Veteran
it would seem... at full speed cruising, we are all getting the same temp air.
this assuming we'd need to be atleast 5-10degrees different to feel the slightest thing. but we seem to be almost all identical.
I suppose the next test would be cruising in 6th at a specific speed, say 65 or 70; on a flat road, recording %load, and MAF.
then we could see if the CAI gets more air through... would that work? I dont know really, seems like it should show us something.
Old May 3, 2004 | 07:15 PM
all_bark's Avatar
all_bark
fun to experiment with thats for sure!
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
z33z_nutz
Sep 23, 2015 07:22 PM
torchkc
Sep 11, 2015 08:26 PM
03daytonablue
Feb 14, 2003 07:19 AM
