Finished DC Headers and Crawford High Flows Today
After about a 12 hour ordeal, I finished the install. I must say that the sound really did not change that much. I have a Greddy EVO on my G Sedan. The sound is a bit deeper. It is a bit louder at WOT, but not bad. The Injen still makes more noise than the exhaust.
Question, I have a slight vibration that seems to be coming from the pass side cat. Can anyone point me in the right direction as to where it would be? I have not really had a look down there yet and everything fit great. I bet it is the rattle from the heat shield that many have complained about.
Butt dyno says, "I don't think many horsepower gained". I'll have to dyno soon and see.
Originally posted by Mike Wazowski
reset ECU perhaps?
with those 2 mods you should have definitely felt a differance.
reset ECU perhaps?
I think not only you need ecu reset, but also a TS ecu flash... I believe Crawford just completed a ecu for their packages, which includes the high flow cats, and headers.. the factory ecu probably will compensate the extra flow with normal settings..
Originally posted by 350xfire
I knew someone would tell me to do that, I need to find instructions. I heard TS web site?
http://www.technosquareinc.com/350reset.htm
It couldn't hurt to try.
You can get the Crawford tuned ECU's here.
http://www.crawfordzcar.com
Victor
Resetting procedures.
Victor
Victor
Thanks for the help.
Originally posted by THX723
Oops, that didn't come out right. I meant to ask, are you still runing your stock Y-pipe?
Originally posted by NismoKid
What difference does it make to reset the ECU compared to not resetting when adding a mod such as headers? Is it something with the A/F ratio? Thanks in advance.
Anyone?
Found my rattle by the way. I left a cat bracket bolt loose.
Originally posted by 350ed
More than likely the rattle is the heat shield as you guessed. I banged my back some during install but it still rattles sometimes.
I got the computer reset and.....I can say that honestly, I don't feel much difference. I am kind of disapointed...
