New Intake option
Here is the new intake I mentioned earlier. The intake tube is made of aluminum and will come in: polished, chrome, or anodized: red, blue, black. A carbon fiber tube may also be available in the near future. The filter is a very high flow drop-in type stainless filter (drop-in replacement). The build of the kit is very high quality. The kit also includes two rubber sleeve to attach to pipe to the plenum and MAF tube.
This intake kit, makes use of the stock air box which is very well designed, shielding the filter from the hot engine bay. A ram-air duct may be an available option soon, and the filter and tube may be purchased separately. I would recommend the tube for those running the JWT pop-charger for a more customized look.
TUBES
FILTERS
BEFORE
INSTALLED
TUBES
FILTERS
BEFORE
INSTALLED
not available yet!.. coming soon i am doing the testing and fit checking and what not...
although i may get a group buy going when it releases in the near future..
An aluminum tube will get hot; the stock tube doesn't. This tube will look better (subjective opinion), but at the cost of performance (although the loss may be minimal to negligible).
every cold air intake on the market seems to use aluminum piping, as well as the intake tubes for turbos and superchargers..
As for the popcharger, you can use the intake pipe WITH the pop charger (will be sold separately)
noting the stainless filter, it is the same filter used by some of the top tuners in japan. I did not do the engineering on this but it definitely flows more air than the stock. I want to test it compared to the K&N drop in filter, but i dont have one at this time.
This is the same setup basically as the new 60k $ Nismo Z ...
stock airbox
metal tubing
high-flow filter
I guess if they put a Nismo badge on it, the thing would sell like hot cakes.
stock airbox
metal tubing
high-flow filter
Originally posted by Road Warrior
the metal tube and stainless filter would be subject to heat soak....and the design appears to be exactly like stock....it looks perty though....what about the dyno?
read my comment above about all aftermarket intakes using metal piping..
